Help with Vector Questions in a Cartesian Coordinate System
In summary: I'm not sure if it is the right place to post my questions to. please let me know if this should be somewhere else.In summary, the conversation discusses finding unit vectors directed from point A towards the origin, point B, and an equidistant point between points B and C. The length of the perimeter of the triangle formed by points A, B, and C is also mentioned. In addition, the conversation delves into the concept of Euclidean vectors and their relationship to directed line segments. There is some confusion and differing opinions on how to approach the problem, due to its imprecise wording.
paulmdrdo1
385
1. let each of the vectors
$A=5a_x-a_y+3a_z$
$B=-2a_x+2_ay+4a_z$
$C=3a_y-4a_z$
extend outward from the origin of the cartesian coordinate system to points A,B, And C respectively. find a unit vector directed from point A toward
a.) Origin b.) point B c.) Equidistant from B and C on the line BC. d.) Find the length of the perimeter of the triangle.
2. The vector $R_{ab}$ extends from A(1,2,3) to B. if the length of $R_{ab}$ is 10 units and its direction is given by $a=0.6a_x+0.64a_y+0.48a_z$ Find the coordinates of B.I already answered letter B in prob 1. but got stuck on the remaining items.
please help. thanks!
Mathematics news on Phys.org
First of all, get vectors going in the right direction, then scale them to get the right lengths.
what do you mean? the vectors already have directions.
$A=5a_x-a_y+3a_z$
$B=-2a_x+2_ay+4a_z$
$C=3a_y-4a_z$
To convert each of the given vectors to unit vectors you would divide each vector by its length.
When they ask for a unit vector from point A to the origin it is hard to know what is wanted since the line of unit length from point A to origin is a directed line segment not a vector. Do they want you to perform a translation of axes so that point A becomes the origin or do they want you to specify the coordinates of a directed line segment of unit length from A towards the origin?
Euclidean vector - Wikipedia, the free encyclopedia
As an informational object, the vector is not as informative as a directed line segment (an ordered list of two points [ A , B ]) but rather expresses the displacement, or vector offset (change in location), A --> B.
Let's not overthink this. An ordered pair of points determines a vector.
So you are saying that the answer would be to specify coordinates for 2 points - one being point A and the other being a point a unit length along the line segment from point A to the origin? Wouldn't this be a directed line segment, not a vector?
No, the problem statement says, "Find a unit vector directed from point A toward a.) origin, b.) point B, ...". I believe one needs to subtract the coordinates of A from the coordinates of the origin (or B) to get the coordinates of the vector $v$ that points from A to the origin (or B), and then divide those coordinates by the length of $v$ to get the coordinates of the unit vector.
So that would give us the negative of the unit vector for A but this is directed from the origin away from point A; which is not what the question asks, but yes, it is probably the intended "correct" answer. This is the reason I detest these problems that are worded imprecisely because forcing you to guess at what answer the professor will consider "correct" is the only way to give the problem any difficulty - and then the difficulty is not in the math. If the professor wanted you to supply the negative of the unit vector then that is what should have been asked for.
Now, the problem of finding the number of unique sets of n objects that can be formed by selecting 0 or more of each of n symbols; I thought that that was a fun problem.
FAQ: Help with Vector Questions in a Cartesian Coordinate System
What is a Cartesian coordinate system?
A Cartesian coordinate system is a mathematical system used to locate points on a two-dimensional plane or in three-dimensional space. It consists of two perpendicular lines, known as the x-axis and y-axis, intersecting at a point called the origin. The coordinates of a point are given by its distance from the origin along each axis.
What are vectors in a Cartesian coordinate system?
Vectors are quantities that have both magnitude and direction. In a Cartesian coordinate system, vectors are represented as arrows with a specific length and direction. The length of the arrow represents the magnitude of the vector, while the direction of the arrow indicates its direction in relation to the axes.
How do you add vectors in a Cartesian coordinate system?
To add vectors in a Cartesian coordinate system, you first need to break down each vector into its x and y components. Then, add the x components together and the y components together to get the resultant vector. The resultant vector can be found by using the Pythagorean theorem to calculate the magnitude and trigonometric functions to determine the direction.
What is the difference between a scalar and a vector in a Cartesian coordinate system?
A scalar is a quantity that only has magnitude, while a vector has both magnitude and direction. In a Cartesian coordinate system, scalars are represented by points on the axes, while vectors are represented by arrows. For example, temperature is a scalar quantity, while velocity is a vector quantity.
Can vectors be negative in a Cartesian coordinate system?
Yes, vectors can have negative components in a Cartesian coordinate system. The direction of a vector is determined by the direction of its components, so if one of the components is negative, the vector will point in the opposite direction. This is often represented by flipping the direction of the arrow or using a negative sign in front of the magnitude.
