Help writing a FIR Filter in Verilog
In summary, to design and build a co-processor for the Leon processor, you should make sure to understand the specifications, break down the problem into smaller parts, use comments and testbenches, and ask for help if needed.
archgold
Hi,
Design and build a co-processor that interfaces to the Leon that implements an FIR filter. Use memory mapped registers on the AMBA APB bus device 12 to communicate with the co-processor. Your C program (and Modelsim Testbench) will transmit the 16 bit filter coefficients and the 16 bit filter inputs to the co-processor, and receive the 16 bit results computed by the co-processor. Assume that the maximum length of the filter is 163. Verify that your co-processor is working correctly in simulation and in hardware. Measure the MAC/s rate that this system can sustain. Compare this to software DSP in part 2a. Report required that covers both parts a) and b) of this project.
Hints:
1) Create a memory mapped register in the PSel12 space with the following format::
a. [2:0] – Op Code
i. InitRAM
ii. Convolve
iii. Load Coefficient
iv. Load Number of Taps
b. [18:3] – 16 bit data to be passed to FSM – InitRAM value, coefficients, filter inputs
c. [31] – Ready bit asserted by FSM indicating status – ready or busy.
N/A
Code:
My Finite state machine:
module MyFSM(Reset,Clk,PWData,PEnable,PWrite,PSel,InitRAM,Busy);
//module MyFSM(Reset, Clk, RAMIn, InitRAM, Busy, Convolution) ;
parameter RAMWidth = 16, RAMAddrWidth = 10, RAMAddrMax = 1023, FilterSize = 163, BufferSize = 61,
ImpulseSize = 64, DataRAMWidth = 1001;
input InitRAM, Clk, Reset, PWData, PEnable, PWrite, PSel ;
input CtrlReg[3:0];
wire[RAMWidth-1:0] RAMInC ;
output Busy;
reg Busy ;
// State encoding
parameter Init = 0,
			 ParseOpCode = 1,
			 Convolve = 2,
			 LoadCoef = 3,
			 LoadNumTaps = 4;
// State Register
reg [3:0] CurrState, NextState ;
// Signals
reg [RAMAddrWidth-1:0] RAMAddrD ;
reg numTaps;
reg [RAMAddrWidth-1:0] RAMAddr ;
wire [RAMWidth-1:0] RAMOut ;
reg RAMWr;
reg CtrlReg[3:0]; // Op Code
reg [32:0] sum;
reg [15:0] RoundedValue;
// Instantiated RAM signals
reg CoeffRAMWr, DataRAMWr;
reg [RAMAddrWidth-1:0]CoeffRAMAddr, DataRAMAddr;
reg [15:0]CoeffRAMIn, CoeffRAMOut, DataRAMIn, DataRAMOut;
assign DRegInLe1 = PSel & PEnable & PWrite & CtrlReg[2:0] ;
assign DRegInLe2 = PSel & PEnable & PWrite & CtrlReg[2:0] ;
assign DRegInLe3 = PSel & PEnable & PWrite & CtrlReg[2:0] ;
assign DRegInLe4 = PSel & PEnable & PWrite & CtrlReg[2:0] ;
//4-input AND gate
//	assign DRegInLe = PSel & PEnable & PWrite;// & PAddr[3:2];// Instantiate RAM
RAM #(RAMAddrWidth,RAMWidth,RAMAddrMax) CoeffRAM(.Clk(Clk),.LE(DRegInLe1),.RAMAddr(RAMAddrD),.RAMIn(CoeffRAMIn),.RAMOut(CoeffRAMOut)) ;
RAM #(RAMAddrWidth,RAMWidth,RAMAddrMax) DataRAM(.Clk(Clk),.LE(DRegInLe2),.RAMAddr(RAMAddrD),.RAMIn(DataRAMIn),.RAMOut(DataRAMOut)) ;
//	Clk,	LE,	Reset_, 	PAddr, 	PWData, 	PRData
DReg D_Reg1(.Clk(Clk),.LE(DRegInLe1),.Reset_(Reset),.D(RAMInC),.Q(PRDataC)); // Coefficient RAM
DReg D_Reg2(.Clk(Clk),.LE(DRegInLe2),.Reset_(Reset),(PRDataD)); // Data RAM
DReg D_Reg3(.Clk(Clk),.LE(DRegInLe3),.Reset_(Reset),.D(RoundedValue),.Q(PRDataV)); // Convolution Result RAM
//DReg D_Reg4(.PWData(sum),.PSel(PSel),.PEnable(PEnable),.PWrite(PWrite),.Reset_(Reset),.PAddr(RAMAddr),.Clk(Clk),.PRData(PRData));
// Combinational block for fsm
always @ *
begin
// Default behavior
  RAMAddrD = RAMAddr ;
  Busy = 0 ;
  NextState = CurrState ;
  RAMWr = 0 ;
// Next State definitions
  case (CurrState)
    Init:
    begin
      // Reset State
      if (InitRAM)
      begin
        // Start initializing the RAM
        NextState = ParseOpCode;
        Busy = 1 ;
        RAMAddrD = 0 ;
      end
    end
    ParseOpCode:
    begin
      // Initialize the RAM - Assert Busy until finished.
      Busy = 1 ;
      RAMWr = 1 ;
      if (CtrlReg == 2)
			NextState = Convolve;
		else if (CtrlReg == 3)
			NextState = LoadCoef;
		else if (CtrlReg == 4)
			NextState = LoadNumTaps;
		else
			NextState = Init;
    end
	 LoadCoef:
	 begin
		Busy = 1 ;
		RAMInC = PWData ;
		RAMAddrD = RAMAddr + 1 ;
		NextState = Init ;
	 end
	Convolve:
	 begin
		Busy = 1 ;
		RAMWr = 1 ;
		//Convolution
		sum = CoeffRAMOut * DataRAMOut;
		sum = sum + 'h0001;
		RoundedValue = RoundedValue + sum[30:15];
		NextState = Init;
	end
	LoadNumTaps:
	begin
		Busy = 1;
		numTaps = 16;
		NextState = Init;
	 end
    default: // Recovery state if you ever get lost
    begin
      NextState = Init;
    end
  endcase
end// Clocked block for fsm
always @ (posedge Clk)
begin
  if (Reset)
  begin
    CurrState <= Init ;
    RAMAddr <= 0 ;
  end
  else
  begin
    CurrState <= NextState ;
	 CoeffRAMIn <= RAMInC;
    RAMAddr <= RAMAddrD ;
  end
end
endmodule
I am lost on what to do, I know this code is incorrect.
Hi there,
Thank you for sharing your code. It looks like you are on the right track with creating a finite state machine to handle the different operations and communicate with the Leon processor. Here are a few suggestions to help you continue with your design:
1. Make sure you understand the specifications and requirements of the project. This will help guide your design decisions and make sure you are implementing the correct functionality.
2. Break down the problem into smaller, manageable parts. For example, you can start by focusing on just one operation (e.g. initializing the RAM) and make sure that works correctly before moving on to the next operation.
3. Use comments in your code to explain your thought process and document your design. This will make it easier for you to keep track of what you are doing and also for others (such as your professor or classmates) to understand your code.
4. Use testbenches to simulate your design and make sure it is working correctly. This will also help you identify any bugs or errors in your code.
5. If you are still unsure about how to proceed, don't be afraid to ask for help from your professor or classmates.
I hope this helps and good luck with your project!
Related to Help writing a FIR Filter in Verilog
1. What is a FIR filter?
A Finite Impulse Response (FIR) filter is a type of digital filter used in signal processing to remove unwanted frequencies from a signal. It is called a finite impulse response filter because the response of the filter to an input signal is finite and only depends on a finite number of past inputs.
2. What is Verilog?
Verilog is a hardware description language (HDL) used to model and simulate digital circuits. It is commonly used in the design and implementation of complex digital systems, including FIR filters.
3. Why is Verilog used for writing FIR filters?
Verilog is used for writing FIR filters because it is a hardware description language that allows for the efficient and accurate modeling of digital circuits. It is also widely used and has a large community of users, making it easier to find resources and support for writing FIR filters.
4. What are the steps for writing a FIR filter in Verilog?
The steps for writing a FIR filter in Verilog include defining the filter coefficients, creating a module for the filter, designing the input/output ports, coding the filter algorithm using combinational logic, and testing the filter using a testbench.
5. What are the advantages of using Verilog for writing FIR filters?
Some advantages of using Verilog for writing FIR filters include its ability to accurately model digital circuits, its availability of built-in libraries for commonly used functions, its ability to simulate and test the filter, and its compatibility with a wide range of hardware platforms.
19K
20K
9K
  • Electrical Engineering
  • General Engineering
