Help: (x-3) is a factor of x^2-4x+c, find c?
  • Thread starter nukeman
In summary, the conversation discusses a problem involving finding the value of c when (x-3) is a factor of the polynomial x^2 - 4x + c. The conversation explores using the theorem that if x-a is a factor of a polynomial f(x), then f(a) = 0. The conversation also discusses a similar problem involving finding the value of c when (x+3) is a factor of the polynomial x^2 - 4x + c.
nukeman
655
If (x-3) is a factor of: x^2 - 4x + c, what is c?
I am really stuck here. When presented with these types of questions, what is the FIRST thing you look at/do ?
Thanks so much.
Thanks so much.
There's a theorem that deals with this. If x - a is a factor of a polynomial f(x), then f(a) = 0.
Here's an example:
f(x) = x3 - x2 - 5x - 3
As it happens, f(x) can be factored into (x - 3)(x2 + 2x + 1).
This means that x - 3 is a factor of f(x). It also means that f(3) = 0. We can verify this by calculating f(3) = 33 - 32 - 5(3) - 3 = 27 - 9 - 15 - 3 = 0.
Thanks so much.
The first thing I ask, is what do you know about polynomials and factoring.
For this problem, "What is the remainder of (x2 - 4x + c)÷(x-3), if (x-3) is a factor of x2 - 4x + c ?"
Holy crap, think I got it. Please let me know if correct?
(3)^2 - 4(3) + c
9 - 16 + c = 0
c = 7
? is that correct?
If (x-3) is a factor of: x^2 - 4x + c, what is c?(3)^2 - 4(3) + c
9 - 16 + c = 0
c = 7
? is that correct?
Do you really have to ask that? Is x-3 a factor of ##x^2-4x+7##? If it is you are done, otherwise you might want to check your arithmetic.
(3)^2 - 4(3) + c
9 - 16 + c = 0
c = 7
? is that correct?
What is 4(3) ?
(It's not 16.)
Oh, I wrote on my paper 4(4)
So correct answer is:
c = +3
Umm... sorry if this is a dumb question, but the last 2 I did, C is always the same as what they are telling is a factor of.
So, this one I just did, they say (x+3) is a factor of... would c automatically be +3?
The answer turned out to be +3.
Can someone give me another simular example to try?
c = +3
Can someone give me another similar example to try?
Work some examples out for yourself.
What is (x-3)(x+4) ?
The one you were solving in this thread has a factor of (x-3).
But, suppose the question is:
If (x+3) is a factor of: x2 - 4x + c, what is c?
If f(x) = x2 - 4x + c, what is f(-3) ?​
Hi sammy.
Ok, so for the question you gave me: If (x+3) is a factor of: x2 - 4x + c, what is c?
c would = -21 ?
nukeman said:
Hi sammy.
c would = -21 ?
Yes.
nukeman said:
Hi sammy.
c would = -21 ?
Nukeman, I will suggest again, when you have a problem like that and you think c = -21 so your function is ##x^2-4x-21##, why don't you just try factoring it yourself and see if x+3 is a factor instead of asking us if -21 is correct?
FAQ: Help: (x-3) is a factor of x^2-4x+c, find c?
What does it mean for (x-3) to be a factor of x^2-4x+c?
When (x-3) is a factor of x^2-4x+c, it means that (x-3) can divide evenly into x^2-4x+c without leaving a remainder.
How do I find the value of c?
To find the value of c, we can use the fact that (x-3) is a factor of x^2-4x+c. This means that when we substitute x=3 into the equation, the result should be equal to 0. So, we can plug in x=3 into x^2-4x+c and solve for c.
Can I solve this equation without knowing the value of x?
Yes, you can solve this equation without knowing the value of x. Since (x-3) is a factor, we can use the fact that when x=3, the equation is equal to 0. This allows us to solve for c without knowing the actual value of x.
What if (x-3) is not a factor of x^2-4x+c? Can I still find the value of c?
If (x-3) is not a factor of x^2-4x+c, then we cannot find the exact value of c. However, we can still find an expression for c using other methods such as completing the square or using the quadratic formula.
How does finding the value of c help in solving the equation x^2-4x+c=0?
Finding the value of c allows us to have a complete solution for the equation x^2-4x+c=0. Knowing the value of c allows us to write the equation in the form of (x-a)(x-b)=0, where a and b are the roots of the equation. This makes it easier to solve for the roots of the equation and find the solution set.
