Henderson Hassalbach equation problem
  • Thread starter hianghao
In summary, to prepare a 1L Tris-HCl buffer 1M pH7, the pKa value of 8.06 must be taken into account. Using the equation pH = pKa + log [base/acid], and the given information that pH = 7 and pKa = 8.06, it is determined that the ratio of base to acid (a/b) is 0.0871. Solving for the molarities of base and acid, it is found that the molarity of HCl to be added is either 0.92M or 0.08M. TRIS hydrochloride is produced when HCl is neutralized, and the buffer is a mixture of salt and
hianghao
I am trying to prepare a 1L Tris-HCl buffer 1M pH7. The pKa value is 8.06. The question is, how many molar of HCl should be added to produce this buffer?
7=8.06 + lg (a/b)
-1.06=lg (a/b)
a/b = 0.0871 -----1
a+b= 1M
a=1-b --------2
Hence,
(1-b)/b = 0.0871
b = 0.92M
a = 0.08M
So, the molarity of HCl to be added is 0.92M or 0.08M. Why?
What reaction takes place when you add HCl?
hianghao said:
C4H11NO3 + HCl <-> C4H10NO2Cl + H2O?
No. HCl is neutralized, but there is no water between products. TRIS hydrochloride is produced.
Because b=salts conc while a=acid/base conc?
Buffer is a mixture of salt & acid/base, but acid and conjugate base.
You need to identify an acid and its conjugate base in the case of TRIS.
What is a Broensted acid? What is a Broensted base? How are they related?
methods
chemical calculators - buffer calculator, concentration calculator
www.titrations.info - all about titration methods
So buffer should be acid+conjugate base or base + conjugate acid.
Bronsted Acid donate proton while base receive proton.
HCl is suppose to be the acid because it has H+ to be donated.
If no water product, could it be
(CH2OH)3CNH2 + HCl <> (CH2OH)3CCl + NH3?
but still it doesn't become TRIS hydrochloride..
Or it becomes (CH2OH)2CClNH2+ CH3OH? I can't hink of other possiblity..
Related to Henderson Hassalbach equation problem
What is the Henderson Hassalbach equation?
The Henderson Hassalbach equation is a mathematical formula used in biochemistry and biology to calculate the pH of a solution based on the concentration of acid and its conjugate base.
What are the components of the Henderson Hassalbach equation?
The equation includes the pH of the solution, the pKa of the acid, and the ratio of the concentration of the acid to the concentration of its conjugate base.
What is the significance of the Henderson Hassalbach equation?
This equation is important because it allows scientists to predict the pH of a solution based on the concentrations of acid and base present. It is also used to understand the behavior of buffers, which are important in maintaining the pH of biological systems.
How do you use the Henderson Hassalbach equation?
To use the equation, first determine the pH of the solution. Then, plug in the known values for the pKa and the concentration ratio of the acid and its conjugate base. Finally, solve for the unknown variable, which is typically the concentration of either the acid or its conjugate base.
What are some limitations of the Henderson Hassalbach equation?
The equation assumes that the acid and its conjugate base are the only components affecting the pH of the solution, which may not always be the case. It also does not take into account the effect of temperature or ionic strength on pH. Additionally, the equation is only valid for weak acids and bases, and may not be accurate for strong acids and bases.
