MHB Hermite Function: Writing x^2r in Polynomial Form
  • Thread starter Thread starter Another1
    Function
To express x^{2r} in Hermite polynomial form, one can utilize the orthogonality of Hermite polynomials. The coefficients a_n can be calculated using the integral a_n = ∫_{-∞}^{∞} x^{2r} (H_n(x))^2 e^{-x^2} dx. This method allows for the determination of the series term by term. For a more general expression, employing the generating function is recommended to derive the (H_n(x))^2 term. The discussion emphasizes the importance of these mathematical tools in achieving the desired polynomial representation.
Another1
How can $$x^{2r}$$ be written in hermite polynomial form?
Mathematics news on Phys.org
The Hermite polynomials are an orthogonal set so if you are looking for [math]x^{2r} = a_0 H_0(x) + a_1 H_1 (x) + \text{ ...}[/math], then
[math]a_n = \int_{-\infty}^{\infty} x^{2r} \left ( H_n (x) \right ) ^2 e^{-x^2} ~ dx[/math]
That will get you the series term by term. If you want a more general expression you'll likely have to use the generating function to get the [math]\left ( H_n (x) \right )^2[/math] expression.
-Dan
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
