Hermitian Operators in QM
In summary, Dr Physics A has been following a series of on-line lectures by Dr Physics B on Hermitian operators for polarization and spin. He clearly defines what they are and what they do, but when he gets to the position and momentum operators he is rather lost. He states that the position operator, Xhat in one dimension, is only defined by the fact that it delivers the eigenvalue, position. The momentum operator, -i d/dx, is hemitian, and comes from the self-adjointness of the momentum operator. He also asserts that the position and momentum operators are not represented by finite-dimensional square matrices, but by operators on an infinite-dimensional vector space. The position and
john t
33
I have been following a series of on-line lectures by Dr Physics A. He clearly describes what Hermitian operators for polarization and spin are and what they do. But when he gets to the position and momentum operators I am rather lost. They are no longer represented by square matrices. The position operator, Xhat in one dimension seems to be only defined by the fact that it delivers the eignenvalue, position. What is the mathematical representation for the operator itself, analogous to the Pauli matrices for spin? As for the momentum operator, he simply asserts it is -i d/dx and proves that it is Hermitian. Where does it come from.
Usually quantum operators act on vectors in an infinite-dimensional vector space, and the operators can't be represented by finite-dimensional square matrices. The position and momentum operators are even more problematic, because there are uncountably infinite sets of position and momentum eigenstates (in contrast to something like the hydrogenic bound orbitals, which form a set that can be numbered with natural numbers). The most important thing about the x and p operators is their commutation relation, and the position representation where p = -i d/dx is only one possible representation where the operators have the right commutator.
First of all, when it comes to unbound operators hemitizity is not enough, you need self-adjointness, but this is a finer mathematical point. I only say this that you are aware of that the following is the usual sloppy physicists' use of mathematics.
It is most simple to start in a concrete representation. In the case of non-relativistic quantum theory it's most easy to start with the position and momentum representations. In the position representation a pure state can be represented by a square-integrable complex-valued function ##\psi(t,x)## (just take one-dimensional motion as the most simple example. Then ##|\psi(t,x)|^2## is the probability distribution for the position of the particles at time ##t##.
To understand why the observables are represented by the operators you learn as the next step, you have to remember how they can be defined in a quasi algebraic way in analytical mechanics. For this you need the Hamilton formalism in the Hamiltonian formulation, i.e., in your case of one-dimensional motion of a particle you have a phase space with a position coordinate ##x## and the canonical conjugate momentum ##p##. The algebra in classical physics is the algebra built by Poisson brackets. For ##x## and ##p## you have ##\{x,p\}_{\text{pb}}=1##. From the point of view of symmetry transformations this tells you that momentum is the infinitesimal generator of spatial translations, and as such you define it also in quantum theory. As a heuristic principle you can thus use "canonical quantization", i.e., you make the classical observables to self-adjoint operators on Hilbert space, and instead of the Poisson brackets you use commutators via the "translation description": ##\{A,B \}_{\text{pb}} \mapsto \frac{1}{\mathrm{i} \hbar} [\hat{A},\hat{B}]##.
Now it's obvious how to define the operators in position representation: Obviously position is represented by multiplying the wave function with its argument ##x##:
$$\hat{x} \psi(t,x)=x \psi(t,x).$$
Now you need another operator for momentum which satisfies the canonical commutator relation
$$\frac{1}{\mathrm{i} \hbar} [\hat{x},\hat{p}]=\hat{1}.$$
It's very easy to see that
$$\hat{p}=-\mathrm{i} \hbar \partial_x$$
fulfills this commutation relation, because for any wave function (that is differentiable!) you have
$$\hat{p} \hat{x} \psi(t,x)=-\mathrm{i} \hbar \partial_x (x \psi(t,x))=-\mathrm{i} \hbar [\psi(t,x)+x \partial_x \psi(t,x)]=-\mathrm{i} \hbar \psi(t,x) + x \hat{p} \psi(t,x),$$
i.e., indeed
$$[\hat{p},\hat{x}] \psi(t,x)=(\hat{p} \hat{x}-\hat{x} \hat{p}) \psi(x)=-\mathrm{i} \hbar \psi(t,x).$$
Since this is valid for any wave function, for which the momentum and position operators are well defined, you indeed have
$$[\hat{p},\hat{x}]=-\mathrm{i} \hbar \hat{1}.$$
Likes bhobba
And also, it's easy to see that one can add any constants (of correct dimensionality) to the p and x operators and they still commute in the right way, because the addition of constants only amounts to a change of inertial reference frame.
Related to Hermitian Operators in QM
1. What is a Hermitian operator in quantum mechanics?
A Hermitian operator is a mathematical operator used in quantum mechanics to represent physical observables, such as position, momentum, or energy. It is a linear operator that satisfies the Hermitian property, meaning that its adjoint (complex conjugate transpose) is equal to itself.
2. What is the significance of Hermitian operators in quantum mechanics?
Hermitian operators are important in quantum mechanics because they represent measurable properties of a quantum system. The eigenvalues of a Hermitian operator correspond to the possible outcomes of a measurement, and the eigenvectors represent the corresponding states of the system.
3. How do Hermitian operators differ from other operators in quantum mechanics?
Unlike general operators, Hermitian operators have real eigenvalues and orthogonal eigenvectors. This means that the outcomes of a measurement are always real and the corresponding states are mutually exclusive. In addition, Hermitian operators are self-adjoint, meaning that they are equal to their own adjoint.
4. Can any observable in quantum mechanics be represented by a Hermitian operator?
Yes, any physical observable in quantum mechanics can be represented by a Hermitian operator. This is known as the Hermiticity postulate, which states that for every observable there exists a corresponding Hermitian operator.
5. How are Hermitian operators used in the mathematical formulation of quantum mechanics?
In the mathematical formulation of quantum mechanics, Hermitian operators are used to represent observables in the Schrödinger equation and to determine the allowed energy levels and eigenstates of a system. They are also used to calculate probabilities of measurement outcomes and to study the dynamics of a quantum system.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
