Hertzian dipole consistent with Biot Savart law at small distances
I don't think you are supposed to know how delta l becomes delta l. That is the current element. You just have to know that it is there...In summary, the problem involves a Hertzian dipole located at the origin of spherical coordinates and aligned with the θ=0 direction. The dipole has a strength of I(subscript 0)δl and oscillates with angular frequency ω. The magnetic field produced by the dipole can be described by the magnetic vector potential, which is given by the real part of the expression B(r)=[(μ(subscript 0)I(subscript 0)δl)/(4π)] sinθ [((-iω)/(rc))+(1/(r^
blueyellow
A Hertzian dipole is located at the origin of spherical coordinates and is aligned with the θ=0 direction. The dipole has strength I(subscript 0)[itex]\delta[/itex]l and oscillates with angular frequency [itex]\omega[/itex]. The magnetic field that it produces is given by the real part of the expression:
B(r)=[([itex]\mu[/itex](subscript 0) I(subscript 0) [itex]\delta[/itex] l)/(4pi)] sin[itex]\theta[/itex] [((-i [itex]\omega[/itex])/(rc))+(1/(r^2))]exp [i(kr-[itex]\omega[/itex]t)] phi-hat
When grouping terms by r-dependence, there are essentially three contribution to the fields produced by a Hertzian dipole: the r^-3 terms are effectively the electrostatic field; the r^-2 terms give rise to what is called the induction field; and, the radiation field is the single term r^-1.
i) Show that, in the limit of small distances r and zero angular frequency, the amplitude of the field given by this expression is consistent with the Biot-Savart law:
B(r)=(([itex]\mu[/itex](subscript 0) I)/(4pi) (([itex]\delta[/itex] l cross r-hat)/(r^2))
ii)Show also that in the limit of large r the form of the expression is consistent with that required for a radiation field.
B(r)=[([itex]\mu[/itex](subscript 0) I(subscript 0) [itex]\delta[/itex] l)/(4pi)] sin[itex]\theta[/itex] [((1/(r^2))]exp [i(kr-[itex]\omega[/itex]t)] phi-hat
B(r)=[([itex]\mu[/itex](subscript 0) I(subscript 0) [itex]\delta[/itex] l)/(4pi)] sin[itex]\theta[/itex] [((1/(r^2))] cos(kr-[itex]\omega[/itex]t) phi-hat
B(r)=[([itex]\mu[/itex](subscript 0) I(subscript 0) [itex]\delta[/itex] l)/(4pi)] sin[itex]\theta[/itex] [((1/(r^2))] cos(kr) phi-hat
B(r)=[([itex]\mu[/itex](subscript 0) I(subscript 0) [itex]\delta[/itex] l)/(4pi)] sin[itex]\theta[/itex] [((1/(r^2))] cos(0) phi-hat
because r is small
B(r)=[([itex]\mu[/itex](subscript 0) I(subscript 0) [itex]\delta[/itex] l)/(4pi)] sin[itex]\theta[/itex] [((1/(r^2))] phi-hat
I suppose I need to find out what theta would be, but I am having trouble visualising the thing in my head. I suppose theta would have to be 90 degrees, but why?
How does one go from delta l to delta l cross r-hat? And how is the phi-hat gotten rid of?
Please help.
And I have no idea how they went from there being an I(subscript 0) in the original expression, to it just being 'I' without the sucript in the Biot-Savart law. What does the I(subscript 0) represent anyway? The initial current? How can there be an initial current? It doesn't appear as if the current is changing. Please help.
The problem is that the given quantity is not the magnetic field, but the magnetic potential vector.
So you have to take the curl of this quantity to get the magnetic field...
So B(r)=[(μ(subscript 0) I(subscript 0) δ l)/(4pi)] sinθ [((-i ω)/(rc))+(1/(r^2))]exp [i(kr-ωt)] phi-hat
is the magnetic vector potential? So it is being suggested that the lecturer who set the homework made a mistake in defining the above equation as B?
I think I will look up what the magnetic vector potential is. But I am going to ask now why you think the above equation represents the magnetic vector potential, just in case after I look it up I am still confused. I'd be grateful if you could explain please.
The simplest i could say is check the units...
The good way would of course be to derive that.
Solve Maxwell's equations for the vector potential in the Lorentz gauge. You get an inhomogenous wave equation. Solve it with Fourier transforms. And you will get the vector potential from that. Then consider the multipole expansion of the vector potential. The second term will be the magnetic dipole you are seeking.
And yes the lecturer indeed made a pretty bad mistake...
And check : "J. D. Jackson: Classical electrodynamics (3rd edition), Chapter 9"
Apparently, the dipole is aligned with theta = 0, and the expression gives B for all space, so the given equation for B is not wrong.
But still, if theta=0, why does the whole expression for B just not go to zero if there is a sin theta in there? Why does it tnd to the Biot-Savart law instead?
The given equation for B is wrong. It is not the equation for B. it is the equation for the vector potential...
Take the curl of this and you get the equation for B.
Thaakisfox, thank you for your help, but since you are the only person who said that the lecturer who set the problem sheet made a mistake, I am still going to assume that there was no mistake in order to try to do the question, because I really don't feel like taking the curl of something right now.
I had a look at part ii) of the question.
ii) Is the answer just that for large distances 1/(r^2)=0? But why would the radiation term remain? Why is complex term (-i*ω/rc) not taken into account for small distances, but taken into account for large distances? Would exp[i(kr-ω t)] be taken into account for large distances? If so, why, if not, why not? I noticed that the question is worth three marks, so I can't believe that all one needs to say that 1/(r^2)=0 for large distances. What else should be said?
And for part i), also assuming that there was no mistake in the question:
I realized that sin θ=θ for small distances, and θ [itex]\times[/itex] [itex]\phi[/itex]-hat=r-hat, but how would one go from θ to θ-hat? How can (θ [itex]\phi[/itex]-hat) be equivalent to r-hat? Can one just change the θ to θ-hat and then just take the cross product? If so, why? If not, why not? And how does [itex]\delta[/itex] l become [itex]\delta[/itex] l, because l was written in bold for the Biot-Savart law but it was not written in bold in the long expression above. And why is it delta l [itex]\times[/itex] r-hat? How does one get the cross product sign from the long expression?
I'd appreciate it if anyone helps please.
i see you are having some problems with basic vector manipulation. But that is not a problem at all, we are all here to learn :))
Sooo the variable you need to consider is the distance r. The angle theta just defines that which point at distance r are we looking at. It is an angle variable. So you have to leave the sine as it is.
Next point is that the cross product is a product of two vectors. Theta is not a vector. Is an angle. Theta hat is indeed a vector. It is the unit vector pointing towards the direction which theta grows.
Now consider r to be small. Then u neglect the radiation field exp(ikr)/r wrt the other part.
Next point is the vector dl. Vector dl is dl times phi hat. As it is pointing in the direction of growing phi. We model the magnetic dipole . dl is the infinitesimal wire length of through which the current generatimh the magnetic dipole moment is passing. Hence vector dl is equal to dl times phi hat.
Hope that is clear till now. Let's see where you got to now.
But do tell your lecturer that mixed the stuff up.
What he did was substituted the magnetic dipole moment instead of the electric dipole moment in the field of electric dipole radiation. But that is not good. The magnetic dipole radiation is the next term in the series and the magnetic and electric fields are a bit different (they r exchanged compared to the electic dipole radiation.) so do tell him to correct his mistake.
Using δl [itex]\phi[/itex]-hat=[itex]\delta[/itex]
B(r)=[itex]\frac{\mu_{0}I_{0}θ}{4\pi r^{2}}[/itex]delta l
But how do I turn the θ into [itex]\times[/itex]r-hat?
Thanks if anyone replies.
Related to Hertzian dipole consistent with Biot Savart law at small distances
What is a Hertzian dipole?
A Hertzian dipole is a theoretical model used in electromagnetics to represent an oscillating electric dipole. It is named after the German physicist Heinrich Hertz.
What is the Biot-Savart law?
The Biot-Savart law is a fundamental law in electromagnetics that describes the magnetic field produced by a steady current. It is named after the French physicists Jean-Baptiste Biot and Félix Savart.
How is a Hertzian dipole consistent with the Biot-Savart law?
A Hertzian dipole is consistent with the Biot-Savart law because the oscillating electric dipole produces a magnetic field, and according to the Biot-Savart law, the magnetic field is proportional to the current producing it. This means that as the electric dipole oscillates, the magnetic field around it also oscillates, following the Biot-Savart law.
What does "small distances" refer to in this concept?
"Small distances" in this concept refer to the distance between the Hertzian dipole and the point at which the magnetic field is being measured. The Biot-Savart law is most accurate at small distances, as it assumes that the distance between the source of the magnetic field and the point of measurement is small compared to the overall size of the system.
What are some real-world applications of the Hertzian dipole consistent with Biot-Savart law at small distances?
Some real-world applications of this concept include the study and analysis of electromagnetic waves, which are produced by oscillating electric dipoles and follow the Biot-Savart law at small distances. This concept is also important in the design and operation of antennas, as they often use Hertzian dipoles to transmit and receive electromagnetic signals.
