Herztian dipole + radiation patterns
In summary: E-field is zero there]In summary, the Hertzian dipole has two terminals attached to a transmission line feeder. The feeder sends RF current into the terminals which in turn produces EM waves. The waves have a circular E-field pattern that looks like a donut. This pattern is due to the current in the transmission line feeder and the magnetic component of the field.
JamesGoh
143
Currently reading over some lecture notes on Hertzian dipoles and I want to confirm my understanding on why the E-field pattern is donut shaped.
1) The Herztzian (aka. 1/2 wave ) diploe has two terminals attached to a transmission line feeder. The feeder sends RF current into the terminals which in turn produce EM waves.
2) Since the transmission line feeder itself consists of current going from one side to another, it is natural that the E-field component of the waves travel from one terminal to another (producing a circular pattern, similar to charges in the Earth's magnetic field)
3) Viewing this pattern from above, one can see the "donut" shaped pattern of the E-field
Thoughts, comments ??
Please feel free to correct me if I am wrong in any concept or theory
Science news on Phys.org
I don't know about the phrase "similar to charges in the Earth's magnetic field", but other than that I think you're on the right track. At any point in time, there will be electric field lines "spraying out" of the positive side of the dipole, wrapping around kind of like a donut and crunching together to squeeze into the negative side of the dipole. The polarity (i.e. the direction of the field, forward or backward, along those lines) will be oscillating back and forth.
It is also helpful not to forget about the magnetic component of the field. Since you have a current in a wire (the dipole), you also have circles of magnetic field pointing around that wire, approximately like a cylinder with the wire as its axis. Since the current is oscillating back and forth, the magnetic field is oscillating between the two different directions around that cylinder. Since a changing magnetic field produces a changing electric field in circles around it, you can now visualize a changing electric field looping around and through the cylinder of magnetic field, like if you wrap a string through a straw and back around to the same end again. That changing electric field will be a bit like the surface of a donut, where the magnetic field is kind of like rings of cream filling inside.
Oh, God, I'm so hungry now...
Hertzian dipoles are much shorter than a half-wave - but as far as radiation patterns go, they have roughly the same pattern.
That's one way of looking at it, but there is a way that can be applied more generally.
Are you familiar with finite element modeling?
In lieu of that, imagine a spherical coordinate system centered on the dipole such that the x-axis is aligned with the elements, and the z-axis is orthogonal to the elements. Define [itex]\theta=0[/itex] as the +z direction, and [itex]\phi=0[/itex] as the x-z plane ([itex]\theta>0[/itex] on the +x side).
If we restrict ourselves to [itex]\phi=0[/itex], the currents in the dipole have no projection perpendicular to the plane, so the fields of this plane would be considered aligned with theta (theta-polarized). Similarly, if we restrict ourselves to [itex]\phi=90[/itex] (the y-z plane), the currents in the dipole have no projection in the plane, so the fields of this plane would be considered aligned with phi (phi-polarized).
What you are calling "above", I would call "a distant point on the x-axis" (defined above). The fields are zero in that direction because the effective aperture is zero.
I'm sure you're aware that the 3D "picture" you describe has an arbitrary size in 3D space. The three dimensions of the pattern you refer to are two spherical angles, and one magnitude (represented as r). It is assumed that the pattern is at constant radius in 3D space, and beyond [itex]\frac{2D^2}{\lambda}=\frac{\lambda}{2}[/itex] the pattern does not change significantly with increasing r.
Care to venture a guess where r=0 with respect to the dipole? :smile:
Regards,
Bill
"Above" refers to the H-plane (or viewing the circular ends of the 2 rods).
Well - a plane isn't a direction, but I know what you mean.
Consider that "above" is (typically) a different direction when one considers a dipole "above" a ground plane.
Regards,
Bill
[addendum: The ends of the dipole fall in the E-plane, not the H-plane]
Related to Herztian dipole + radiation patterns
1. What is a Herztian dipole?
A Herztian dipole is a type of antenna that is used to transmit and receive electromagnetic radiation. It consists of two equal and opposite charges oscillating in an electric field, which creates a dipole moment and produces radiation.
2. How does a Herztian dipole create radiation patterns?
The radiation pattern of a Herztian dipole is determined by the orientation of the dipole moment and the direction of the electric field. As the dipole oscillates, it produces a changing electric field that radiates outward in a specific pattern.
3. What factors affect the radiation pattern of a Herztian dipole?
The radiation pattern of a Herztian dipole is affected by the length of the dipole, the frequency of the oscillations, and the environment in which it is placed. Additionally, the orientation of the dipole and the presence of nearby objects can also impact the radiation pattern.
4. What is the significance of radiation patterns in antenna design?
Radiation patterns are crucial in antenna design as they determine the direction and strength of the electromagnetic radiation. Engineers use radiation patterns to design antennas that can transmit and receive signals efficiently in a specific direction or over a specific area.
5. How can radiation patterns be visualized and measured?
Radiation patterns can be visualized using specialized software or by using physical models and measuring equipment. The most common way to measure radiation patterns is by using a test antenna and a receiving antenna to map out the signal strength in different directions.
