reddevil2576
- 54
Has anyone come up with a design for an HBO generator to run an engine just on hho? How many lpm would I need to produce to run a 6.4 litre v8
An HHO generator, also known as a hydrogen fuel cell, is a device that uses electrolysis to split water molecules into hydrogen and oxygen gas. The resulting HHO gas, a mixture of hydrogen and oxygen, is then used as a supplemental fuel source in internal combustion engines.
Yes, an HHO generator can be designed and installed on a 6.4L V8 engine. However, it is important to note that the effectiveness of the generator may vary depending on the specific engine and its condition.
The use of an HHO generator on a 6.4L V8 engine can potentially improve fuel efficiency, increase power and torque, reduce emissions, and prolong engine life. It can also provide a more complete combustion, resulting in a smoother and quieter engine operation.
Some potential drawbacks of using an HHO generator on a 6.4L V8 engine include the initial cost and installation process, as well as the need for regular maintenance and refilling of the electrolyte solution. There may also be compatibility issues with certain engine components or modifications.
The design and installation process of an HHO generator on a 6.4L V8 engine can vary depending on the specific engine and the chosen generator kit. It may require some technical knowledge and tools, but there are also pre-made kits available for easier installation. It is recommended to follow the instructions provided by the manufacturer and seek professional assistance if needed.
