Hi can you help me in solving this from coordinate geometry?
In summary: In that case you can easily find ##\phi##.In summary, to find the equation of a line passing through point A (1,2) and whose perpendicular distance from the origin is maximum, you can use the straight line normal form equation: ##|C'| = (1,2)\;\cdot\; (\cos\phi, \sin\phi)## and find the value of ##\phi## that maximizes this expression. This can be done by differentiating the expression or by using vector products and setting ##\alpha = 0##. Once you have the value of ##\phi##, you can substitute it back into the original equation to find the equation of the line.
kay
60
< Mentor Note -- thread moved to HH from the technical math forums, so no HH Template is shown >
Find the equation of a line passing through point A (1, 2) and whose perpendicular distance from origin is maximum.
Start by drawing a sketch showing the coordinate axes and point A.
Draw an arbitrary line which passes thru point A.
Can you figure out how to determine the perpendicular distance from this arbitrary line to the origin?
Yes. If that eqn is Ax + By + C = 0
then the distance from origin is |C|/√(A^2 + B^2)!
Ax + By + C = 0 isn't the whole story.
A straight line in the plane has two degrees of freedom only, not three like your equation suggests. And this line has to go through point (1,2), so there can't be more than one degree of freedom (e.g. the slope).
You can eliminate one degree of freedom by requiring A2 + B2 = 1 (effectively dividing by ##\sqrt{A^2+B^2}## -- and no fear of dividing by zero; why not ?)
That means the new A and B can be written as ##\cos\phi## and ##\sin\phi## for some angle ##\phi## (well, not just 'some' angle...)
Congrats! you have just derived the so-called http://doubleroot.in/straight-line-normal-form/equation for a straight line !Not there yet: the line has to go through (1,2), so you now eliminate C by substituting the coordinates of point A.
According to your equation the new C ( let's call it C' ) is then the distance to the origin, so you have that in terms of xA and yA.
If you know about maximizing a function, you can differentiate that expression and thus find ##\phi##
If you know about vector products, you can also see that the left hand side is a dot product of two vectors: ##|C'| = (1,2)\;\cdot\; (\cos\phi, \sin\phi)## and the absolute value of that is $$|C'| = |(1,2)| \; |(\cos\phi, \sin\phi)| \; cos\alpha$$ where ##\alpha## is the angle between the two vectors.
And then |C'| is clearly maximum if ##\alpha = 0## (the two vectors are collinear).
Related to Hi can you help me in solving this from coordinate geometry?
1. What is coordinate geometry?
Coordinate geometry is a branch of mathematics that deals with the study of geometric figures using a coordinate system. It involves using algebraic equations and geometric concepts to determine the properties of points, lines, and shapes on a coordinate plane.
2. How do I solve problems in coordinate geometry?
To solve problems in coordinate geometry, you need to first understand the basic concepts and principles, such as the distance formula, slope formula, and Pythagorean theorem. Then, you can use these concepts to set up and solve equations to find the coordinates of points, equations of lines, and other geometric properties.
3. Can you explain the distance formula and how to use it in coordinate geometry?
The distance formula is used to find the distance between two points on a coordinate plane. It is given by d = √[(x2-x1)^2 + (y2-y1)^2], where (x1, y1) and (x2, y2) are the coordinates of the two points. To use the formula, simply plug in the coordinates into the equation and solve for d.
4. How do I find the slope of a line in coordinate geometry?
The slope of a line is a measure of its steepness and is given by the ratio of the change in y-coordinates to the change in x-coordinates. It can be calculated using the slope formula, m = (y2-y1)/(x2-x1), where (x1, y1) and (x2, y2) are any two points on the line. Simply plug in the coordinates and solve for the slope.
5. Is it important to use a coordinate system in coordinate geometry?
Yes, using a coordinate system is essential in coordinate geometry as it provides a visual representation of geometric figures and allows for precise calculations and measurements. Without a coordinate system, it would be difficult to solve problems and communicate geometric concepts accurately.
