- #36
Tom.G
- 4,290
Yes. It is ten minutes before midnight here and I was looking at your latest results.michael1978 said:Goodmorning Tom are you here somewhere….
Something is not right. TP15 should be Ground, 0V. Where was the other voltmeter lead when you measured 2.6V at TP15?michael1978 said:FM voltage is 8.6V at the battery, the TP2 AND TP15 stay at 2.6V,
The following was typed before I noticed the TP15 voltage. I will leave it here in case the TP15 voltage was just a measurement error. (That way I will not have to type it again.) Please check the TP15 voltage, and correct any errors, before doing the below tests.
There seems to be a problem with either the power supply (battery and C39) or something around the LM386.
Please check that C39 is the correct value (470uF) and installed in the right direction. If it is wired backwards that would be a problem. Also make sure the solder connections are good.
Check all the parts around the LM386. Make sure they are the correct value and in the right spot.
C42 = 10uF, C43 = 470uF, C44 = 0.047uF. C42 and C43 must be installed the correct direction.
R44 = 47 Ohm (Yellow Violet Black), R45 = 10 Ohm (Brown Black Black)
Check jumpers J2 and J3 that they are in the right location and soldered.
Check soldering of the socket for LM386.
Sometimes when an IC (LM386) is put in a socket, a pin will bend and not plug into the socket. Check that all the LM386 pins are in the socket. You may have to unplug the LM386 to see if a pin is bent.
(The time here is now 30 minutes after midnite.)
Cheers,
Tom
