Hi-pot test of a circuit with a diode
In summary: The test is to make sure that the voltage is in the right direction and that the ohm reading is in one direction. If the ohm reading is in the other direction then it is a failure.The test is to make sure that the voltage is in the right direction and that the ohm reading is in one direction. If the ohm reading is in the other direction then it is a failure.
  • #36
bramdam said:
Jim,
I laid out four options to resolve this issue and they chose to re-evaluate their hi-pot testing procedure. In the meantime they will tie the leads of our heater together, after the contactor, to avoid presenting a voltage differential across it. I could not get one to fail testing it this way at our shop. They too are weary of changing the part at this time so did not bite on putting a surge device in parallel.
understand. Your fix will work.
(Just for your bag of tricks) That 1KV zener should halve the heater power for you , just like the diode you're using. It'd survive the hi-pot too.
glad you got a path to success !
old jim
Likes 1 person
<h2>What is a Hi-pot test?</h2><p>A Hi-pot test, also known as a high potential test or dielectric withstand test, is a type of electrical test used to determine the insulation strength of a circuit or device. It involves applying a high voltage to the circuit and measuring the current that flows through it.</p><h2>Why is a Hi-pot test necessary for circuits with diodes?</h2><p>A Hi-pot test is necessary for circuits with diodes because diodes are sensitive to high voltages and can be easily damaged if the insulation is not sufficient. This test helps ensure that the diode and other components in the circuit can withstand high voltages without failure.</p><h2>How is a Hi-pot test performed?</h2><p>In a Hi-pot test, a high voltage source is connected to the circuit and the voltage is gradually increased until it reaches the desired test voltage. The current is then measured to determine if the circuit can withstand the high voltage. The test is usually performed for a specific amount of time, typically a few seconds, to simulate real-world conditions.</p><h2>What are the safety precautions for performing a Hi-pot test?</h2><p>Safety precautions for performing a Hi-pot test include wearing appropriate personal protective equipment, ensuring that the test equipment is properly grounded, and following the manufacturer's instructions for the test equipment. It is also important to carefully monitor the test and be prepared to quickly disconnect the circuit in case of any issues.</p><h2>What are the potential risks of a Hi-pot test?</h2><p>The main risk of a Hi-pot test is damaging the circuit or components if the test voltage is too high or if there are any defects in the circuit. There is also a risk of electric shock if proper safety precautions are not followed. It is important to carefully plan and execute the test to minimize these risks.</p>
FAQ: Hi-pot test of a circuit with a diode
79K
