morrobay
- 1,353
[Mentor's note: Moved from a thread about field theories as this is just about the basic meaning of the theorem for ordinary entangled particles]]
Suppose that there are photon spin outcomes that are pre existing from entanglement or from local hidden variables.
For every detector angle Alice selects there is a result that is correlated with every detector angle Bob selects.
With 10 units that would be 360 x 360 mutual outcomes.
* In order to have the probabilities that produce correlations that match quantum mechanical predictions;
opposite results cos2 (β - α ) or same sin2 (β - α ) you allow for the probability that Alice gets a given result on her particle (for any detector angle)
to vary with the direction that Bob chooses to measure on.
This could be a local hidden variable model for relative angles between detectors
*In part from post #12 comparison between quantum entanglement and a classical version.
Simon Phoenix said:The essence of the argument for me is that for a hidden variable theory to reproduce the predictions of QM it's going to have to produce a correlation function that has a functional dependence on the relative angle of the detector settings. So in an appropriate frame if Alice changes her mind at the last moment about her measurement setting there can be no way this 'information' is transmitted to Bob's location before Bob's measurement - certainly not with a locally causal field. The role of the hidden variables is to make explicit the reasons for an observed correlation. So although the correlation happens because of some prior connection we can't apply the same reasoning to the last minute change of setting, which for want of a better word occurs pretty much in the 'present'. It's that potential change that must, somehow, be accommodated within our hidden variable description. How does that happen within a causal locally realistic description? I'm not seeing any possible physical explanation of that (within the context of a hidden variable theory).
