Hiesenberg uncertainty principle, h or hbar?
In summary: This applies to the standard deviation of two observables and is a fundamental principle in quantum mechanics. However, other uncertainty relations can be found in the literature using different measures of spread. In summary, there is an uncertainty relation in quantum mechanics that states that the product of the standard deviations of two observables is greater than or equal to half of the reduced Planck's constant. This is often seen as hbar/2, but may differ depending on the measure of spread used.
rash92
i've seen both:
ΔxΔp >= h/2
and
ΔxΔp >= hbar/ 2
used, and I'm not sure which is correct. my physics textbook uses h/2, but wiki and other online rescources seem to use hbar/2
do they apply to different situations? (if so, where do you use hbar and where do you use h?) or is one of them outdated?
No, the only generally correct statement is about standard devitians of two observables. For any (pure or mixed) state, one has
[tex]\Delta A \Delta B \geq \frac{1}{2} |\langle [\hat{A},\hat{B}] \rangle|.[/tex]
Since for position and momentum components in the same direction, you have
[tex][x,p]=\mathrm{i} \hbar[/tex]
you have
[tex]\Delta x \Delta p \geq \hbar/2.[/tex]
Other uncertainty relations are found in the literature from hand-waving arguments using other uncertainty measures than the standard deviation!
so if I'm understanding correctly, if you use standard deviation, it's always hbar/2,
but if you use other measures of spread then it could be different?
rash92 said:
i've seen both:
ΔxΔp >= h/2
and
ΔxΔp >= hbar/ 2
Your physics textbook is wrong, the correct inequality is the one with hbar.
FAQ: Hiesenberg uncertainty principle, h or hbar?
What is the Heisenberg uncertainty principle?
The Heisenberg uncertainty principle, also known as the uncertainty principle, is a fundamental concept in quantum mechanics that states that it is impossible to know with absolute certainty both the position and momentum of a subatomic particle at the same time.
2. Who is Werner Heisenberg and what is his contribution to the uncertainty principle?
Werner Heisenberg was a German physicist who is credited with formulating the uncertainty principle in 1927. He showed that the more precisely one knows the position of a particle, the less precisely one can know its momentum, and vice versa.
3. What is the difference between h and hbar in the uncertainty principle?
In the uncertainty principle, h is Planck's constant, which represents the fundamental unit of action in quantum mechanics. Hbar, also known as h-bar, is the reduced Planck's constant, which is equal to h divided by 2π. It is used to simplify calculations in quantum mechanics.
4. Can the uncertainty principle be violated?
No, the uncertainty principle is a fundamental law of quantum mechanics and has been supported by numerous experiments. It is a cornerstone of our understanding of the behavior of subatomic particles and cannot be violated.
5. How does the uncertainty principle affect everyday objects?
While the uncertainty principle is typically discussed in the context of subatomic particles, it also applies to everyday objects, just on a larger scale. However, the effects are so small that they are not noticeable in our everyday lives. The uncertainty principle becomes more significant for objects with extremely small masses, such as electrons.
