Higgs boson and the mass of W and Z
In summary: The sphere will now be asymmetric under the group of rotations, since one rotation will take it towards the axis towards Earth, while another rotation will take it away from Earth. The sphere is now not symmetric under the group of rotations, it has an axis of rotation which is different from all the others. This is what's happening with the universe. The laws of physics are the same everywhere, but the symmetries are broken.
Unredeemed
120
Thanks for everyone's help so far, it's been extemely useful for researching my talk.
Whilst doing other research for my talk I came across this on wikipedia: "More specifically, the Higgs boson would explain the difference between the massless photon and the relatively massive W and Z bosons." - http://en.wikipedia.org/wiki/Higgs_boson
I know that at 10^15K electromagnetism and the weak nuclear force merge to create the electroweak force. But why does the fact that the W and Z boson are different to the photon? Surely that's simply because they're different particles? Or could the Higgs give us an incite as to what these bosons "are."
My main question is, how could the higgs boson "explain the difference between the massless photon and the relatively massive W and Z bosons."?
Thanks,
Jamie
This question is no longer relevant to your original thread AND it is not actually "Beyond the Standard Model". It has been moved to the appropriate forum
Zz.
Zz.
I thought the Higgs would have classified as BTSM.
Standard Model contains a fundamental gauge symmetry SU(2)xU(1). QFT predicts that, if the symmetry is unbroken, there should be one massless particle (force mediating gauge boson) for each generator. SU(2)xU(1) has four generators, therefore there should be four particles with identical properties.
In our universe SU(2)xU(1) is somehow broken, we don't know exactly how, but Higgs is a likely breaking candidate. Higgs field interacts with four gauge bosons and turns them into a photon, Z, W+, and W-. Since the symmetry is broken, gauge bosons no longer have to be identical.
To give you a crude visual picture of what's happening. Imagine a sphere. If it's suspended in space with no gravitating objects nearby, all points on the sphere are equivalent to each other. Laws of physics are the same everywhere. A mathematician would say that the sphere is symmetric under the group of rotations which is SO(3). Any rotation can be described as a combination of rotations around three predetermined axes. (Since SO(3) has three generators) Since the symmetry is exact, you can pick any three axes you want.
If you place the same sphere inside Earth's field of gravity, it will obtain a preferred axis (towards Earth).
Related to Higgs boson and the mass of W and Z
1. What is the Higgs boson and why is it important in understanding the mass of W and Z particles?
The Higgs boson is a subatomic particle that was first theorized in the 1960s as a crucial component of the Standard Model of particle physics. It is responsible for giving particles mass through interactions with the Higgs field, which permeates the entire universe. The discovery of the Higgs boson in 2012 at the Large Hadron Collider confirmed this theory and provided insight into the origin of mass in the universe. W and Z particles are known as "gauge bosons" and their masses are directly related to the strength of their interaction with the Higgs field.
2. How was the Higgs boson discovered?
The Higgs boson was discovered through experiments at the Large Hadron Collider (LHC) in Geneva, Switzerland. Scientists collided protons together at high energies and observed the decay products to look for evidence of the Higgs boson. This process required the use of advanced technology and data analysis techniques, as the Higgs boson is a very rare and short-lived particle.
3. What is the mass of the W and Z particles?
The mass of the W and Z particles is approximately 80.4 and 91.2 GeV/c^2, respectively. This is about 80-90 times the mass of a proton. The precise mass values were determined through experiments at the LHC and are consistent with the predictions of the Standard Model.
4. How does the Higgs boson impact our understanding of the universe?
The discovery of the Higgs boson has provided a deeper understanding of the fundamental forces and particles that make up the universe. It confirmed the validity of the Standard Model and also opened up new avenues for research, such as the search for physics beyond the Standard Model. The Higgs boson is also important in theories related to the origin of the universe and the existence of dark matter.
5. Are there any practical applications of the Higgs boson?
While the discovery of the Higgs boson may not have immediate practical applications, it has helped to advance our understanding of the universe and could potentially lead to new technologies in the future. For example, the technology used to discover the Higgs boson, such as the Large Hadron Collider, could have spin-off effects in other fields such as medicine and energy production.
