High frequency being transformed to a low frequency
In summary, the OP has an idea for a way to make a sound that is lower in frequency than what is currently being produced, but they are not sure if it is possible or not.
Dimitar63
Hi Physics,
I have an idea but before i start. I must know am I right. Is it possible?
We have a small room with two objects. The first object is a producer of sound waves out of the human hearing range. This object sends ultra sound waves to the second object. The second object start to resonate and produces a sound that can be heard. This (second object) has an acoustic shape , so small you can hold in your hand. It depends on the material and the shape of the object i know. But is it possible high frequency be transformed to frequency low enough to be heard?
It is probably not impossible to make a mechanical device, but a small battery, microphone and speaker would make it much easier. You can skip the battery if you are fine with a low conversion efficiency.
Yes. There's the rub. If you are not using dangerous levels of Ultrasound from your 'producer' the losses will be too great. You will need an Active Circuit to achieve what you want, I am sure. If you really need to do without electronics then the alternative would have to be a pretty large (and accurate) device, to catch enough of the reflected ultrasonic energy. Frequency shifting, with a mixer circuit is very easy and there are many circuit designs available. Bat detectors are available at not much cost and they are probably cheaper than you can build yourself unless you already have the basic constructor's kit. These do what you seem to be describing but your need to be a bit fuller in specifying your requirement if you want a practical answer.
I'm curious about the OP's conditions, not doing it electronically (easy).
I think they are asking - is there some physical means by which a high frequency sound wave can cause another object to produce a much lower frequency wave? Off hand, I don't think there is?
I was thinking of pulsing the ultrasonic wave on/off at the resonant frequency of the lower-tuned object, but I think that would just produce a sound on it's own, which is not what OP is looking for, I think.
What about two ultrasonic waves ~ 1000 Hz apart? Could the resonant device manage to be moved by the difference frequencies in a strictly mechanical means? Would some sort of mechanical non-linearity provide this (as it does in an electrical circuit)?
I think non-linearity of a material or structure would be needed, but unless the amplitude is very large, it seems difficult to have a mechanical structure exhibit a non-linearity...
Contact interactions can be nonlinear. I could imagine a system vibrating at high frequencies mechanically hit another system resonating at lower frequencies. Would give a horrible conversion efficiency, of course.
OP didn't specify the application, unfortunately.
Yes it should be possible and yes it would be a nonlinear process. There are ways to generate subharmonics, phase coupled difference interactions, inefficient resonance, and such. It really just depends on the application and specifics of your system.
I do wonder though, if the energy of high-frequency ultrasonic waves, converted in somewhat efficient means to low frequency would have enough energy to be clearly audible? I think about the exhibit where you can whisper on one side of a large expanse near a parabolic mirror and it can clearly be heard on the other side of the room. I forget where that is but I've witnessed it...
The Exploratorium in San Francisco has such an exhibit, or at least they used to. Pretty amazing.
Hey, what about using the Doppler Effect to reduce the frequency of the sound? If you reflected the ultrasound off of a moving membrane, the frequency of the reflected energy would be shifted above and below the original frequency depending on how fast the membrane was oscillating...
EDIT / ADD -- https://www.physicsforums.com/threads/doppler-effect-moving-source-with-reflection.79074/
I'm east coast, maybe The Smithsonian? It has been so long I forget...
I actually saw this recently, the focus was on our perception and 'filling in' for missing harmonics, but he actually demonstrates a system that provides a 'sub-harmonic'.
Essentially, a resonant chamber making contact with something else, like a piece of foil. But the foil, acting on its own resonance, moves back-forth, making intermittent contact with the source wave. So it vibrates at a lower frequency than the source. This could be tuned and optimized beyond the simple demonstration of principle here, but I suppose the efficiency would be very low - but possible.
Here you go - he demonstrates it in the first 10 seconds!
The entire video, and his others in the series are pretty amazing. I subscribed.
https://en.wikipedia.org/wiki/Acoustic_mirror
Likes jerromyjon
Okay boys, first I want to thank you for your replies.
And.. I start thinking, what if I use a quartz crystal as a resonator? Is it possible quartz to produce a voltage and power small buzzer?
ultrasound waves --> quartz crystal --> small buzzer
What is the application you have in mind?
Where does the ultrasound come from?
No way, without a battery / power source. Quartz crystals are not good for passive operation. In any case, you are wanting frequency conversion (twice?) which means loss loss loss which has to be made up with amplification.
There are some ways. Electronically, it's easy, and there are such devices, called leak detectors. You point them in the direction you think there might be a leak in a pressurized system and it will detect ultrasound leaks, translating them to a hiss at a frequency within ear range.
If your source of the sound could transmit two ultrasound signals at slightly different frequencies, a resonant receiver can interact and produce heterodyne frequencies, which are a series of frequencies that are additions, subtractions, and their multiples of the original frequencies. One of these lower frequencies can then be within hearing range. Heterodyne frequencies are used in FM radio transmission and in other devices such as micro wave ovens.
Nifty idea b. , might work if the ultrasound frequency isn't too far above the limits of audibility. The Doppler formula ( f' = fv/[v+vs] ) is valid only if the moving source speed is << speed of the incident sound. I'm no expert here for sure but I read that linearity between air molecular displacement and restoring force is lost & you get weird things like sonic booms etc. At what point the breakdown vs/v starts to occur I don't know. My Resnick & Halliday just says "when vs becomes appreciable in magnitude with v".
Likes berkeman
Dimitar63 said:
Hi Physics,
If the second object resonates it will resonate with the frequency of the broadcasted sound and higher harmonics. If the radiated frequency is higher than hearing range, the higher harmonics will also be ultrasonic. Or am I missing what you are asking?
It's a shame that the information we have been fed is so sparse. Without some idea about the power levels involved and the nature of the 'Objects', there is very little to be said. I wish people would be more forthcoming with their initial questions. It would save a lot of time and avoid misunderstandings. This is an Engineering project and the numbers really count!
Likes mfb
My first thought would be for the transmitter to send two ultrasound signals. One designed to be converted to electric power, the other to be received as the signal. This would allow you to place the piezo-electric crystal in a resonant environment with the hope of capturing some significant portion of the audio power collected through the aperture. It also allows the power converter to be optimized for that one frequency.
I would say it could certainly be done. All the OP has requested is that it be heard - not that it be especially loud.
All the numbers are important here. What is the output power? What is the efficiency of both transducers and mixer? What power output of the system is required?
This won't work just because it sounds like a nice idea.
It strikes me that if such a system were workable it would already be for sale as a novelty, if nothing else.
Related to High frequency being transformed to a low frequency
1. What is the definition of high frequency being transformed to a low frequency?
High frequency being transformed to a low frequency refers to the process of converting a signal or wave with a high frequency into a signal or wave with a lower frequency. This can be done through various methods such as filtering, mixing, or modulation.
2. Why would someone want to transform high frequency to low frequency?
There are several reasons why someone may want to transform high frequency to low frequency. One common reason is to reduce the amount of interference or noise in a signal. Lower frequency signals are less susceptible to interference and can therefore provide a clearer and more reliable transmission. Additionally, transforming high frequency to low frequency can also make it easier to process and analyze the signal.
3. How is high frequency transformed to low frequency?
High frequency can be transformed to low frequency through a variety of techniques. Some common methods include using filters to remove high frequency components, using mixers to combine high and low frequency signals, or using modulation techniques to shift the frequency of a signal. The specific method used will depend on the desired outcome and the characteristics of the original signal.
4. What are the applications of transforming high frequency to low frequency?
Transforming high frequency to low frequency has many practical applications. It is commonly used in communication systems to improve signal quality and reduce interference. It is also used in audio processing to remove unwanted high frequency noise from recordings. In addition, high frequency transformation is essential in fields such as radio astronomy and medical imaging to extract useful information from high frequency signals.
5. Are there any limitations to transforming high frequency to low frequency?
While transforming high frequency to low frequency can be beneficial in many cases, there are also some limitations to keep in mind. Depending on the method used, there may be some loss of information or degradation of the signal. Additionally, certain types of signals may not be able to be transformed without significant distortion. It is important to carefully consider the potential implications and limitations before choosing to transform high frequency to low frequency.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
