High pass filter for pulse shaping
In summary, the individual has been conducting experiments using a MOSFET and a small function generator that outputs square waves at a fixed 50% duty cycle. They attempted to use a high pass filter to shorten the width of the pulses and adjust the voltage level, but encountered issues with the MOSFET not switching on. They are seeking advice on how to modify the high pass filter to produce positive voltage spikes that can successfully switch on the MOSFET.
Jdo300
554
Hello All,
I have been doing some experiments where I need to make a very short pulse to switch on and off a MOSFET I am using (IRF840) but all I have as a pulse source is a small function generator which outputs square waves fixed at 50% duty cycle.
So I had an idea to use a simple high pass filter like this one mentioned on Wikipedia:
http://en.wikipedia.org/wiki/High_pass_filter
So I decided to duplicate the simpe circuit to shorten the width of the pulses coming out of my function generator. The output square wave was about 4V with a +2V DC Offset. I put the output in series with a 3.4nF cap and a potentiometer to adjust the width. Then I fed that output directly to the gate of the MOSFET. But It didn't switch the FET on.
So I took off the FET and replaced it with a 2KOhm resistor and scoped across that to see what the output looked like. It appeared that I was getting nice spikes but they were going negative rather than positive.
So I'm wondering if someone could give me a tip on how to adapt the high pass filter to make positive voltage spikes that I can use to switch on my MOSFET. Any help/advice appreciated :smile:
Thanks,
Jason O
If you have a 0-4V square wave and follow it with a capacitor and then a resistor to ground as you describe, then you should be seeing +/-2Vp spikes at the square wave edges, centered on 0V. In order to protect the MOSFET gate, you should probably put in a clamping diode from ground to your gate (clamps the negative spikes at -0.6V instead of allowing -2V).
Hi Jason,
Thank you for sharing your experiment and question with us. It seems like you have a good understanding of using a high pass filter for pulse shaping. However, I think the issue you are facing is with the polarity of the output spikes from your filter.
Firstly, I would suggest double checking the connections and values of your circuit to make sure there are no errors there. If everything seems correct, then the issue may lie in the type of high pass filter you are using.
The high pass filter you mentioned from Wikipedia is a first-order filter, which means it only has one reactive component (the capacitor). This type of filter is known to produce spikes with opposite polarity to the input signal, as you have observed.
To get positive voltage spikes, you could try using a second-order high pass filter, which has two reactive components (a capacitor and an inductor). This type of filter is known to produce spikes with the same polarity as the input signal.
Alternatively, you could also try using a Schmitt trigger circuit, which is specifically designed for pulse shaping and produces sharp positive spikes. You can find many circuit diagrams and explanations online for this type of circuit.
I hope this helps and good luck with your experiment! Keep exploring and experimenting, that's how we learn and innovate. :)
Related to High pass filter for pulse shaping
1. What is a high pass filter for pulse shaping?
A high pass filter for pulse shaping is a type of electronic filter that is used to modify the shape of a pulse or signal by allowing high frequency components to pass through while blocking low frequency components.
2. Why is a high pass filter used for pulse shaping?
A high pass filter is used for pulse shaping to eliminate low frequency noise or distortion from a signal, resulting in a cleaner and more defined pulse shape. It is commonly used in communication systems to improve the quality and reliability of transmitted signals.
3. How does a high pass filter work?
A high pass filter works by attenuating or reducing the amplitude of low frequency components in a signal, while allowing high frequency components to pass through relatively unaltered. This is achieved by using a combination of resistors, capacitors, and/or inductors to create a frequency-dependent impedance that blocks low frequencies.
4. What are some common applications of a high pass filter for pulse shaping?
High pass filters for pulse shaping are commonly used in digital signal processing, audio and video processing, telecommunications, and control systems. They are also used in medical devices, such as ECG machines, to filter out low frequency noise and interference.
5. How do I choose the appropriate high pass filter for my application?
The appropriate high pass filter for your application will depend on the specific requirements of your signal and the frequency range that needs to be filtered. Factors to consider include the cutoff frequency, filter type (e.g. Butterworth, Chebyshev, Bessel), and the desired roll-off characteristics. It is best to consult with an expert or use online tools to help select the most suitable high pass filter for your specific needs.
