High pitched noise with some elctronics
  • Thread starter LT72884
  • Tags
    Noise
In summary, the printer's stepper motors were not working properly because the voltage was set incorrectly. The recommended voltage was increased, and now the printer has a low-pitched hissing sound. Other electronic devices, such as a wall wart for a cell phone, or a gpu in a PC, also produce this sound. It is not uncommon, and is not a warning sign of a problem.
LT72884
335
49
Hello:)
I am working on my new 3d printer and i came across an interesting situation. According to the manufacture, my stepper motors need to have a voltage of roughly 0.95 volts.
I checked mine and they were 0.81 volts, hence the not so smooth prints. Ok, so i increased the voltage to the recommended specs they told me to. Now the most fascinating thing has happened and i do not know if its just me or what.
But when i power the machine on, home it to its home position, once the motors have stopped moving, i can hear this low volume high pitched sound like a hissing sound. I sometimes hear this same sound with other electronic devices as well, such as my wallwort for my cell phone, or my gpu in my PC. the apartment is a new complex and the power is clean and grounded.
What is this sound and should i be worried. I mean, others can't hear it but i can. Its high pitched haha
thanks
Probably just magnetostriction in the switching power supply magnetics. I wouldn't worry about it as long as the electronics are working correctly.
Likes davenn, LT72884 and rbelli1
And the ceramic capacitors are piezoelectric.
There is a whole chorus inside modern electronics.
BoB
Likes jim hardy, anorlunda and LT72884
The electronics seem to be working fine. it prints and does what i need it to. I was thinking it was something to do with magnetics. thanks again
Yeah... squeals from switch mode PSU's are very common
The cheap ones anyway, LOL. Mine didn't ever squeal. On the other hand, you could never afford to put them in a consumer printer.
Likes davenn
Its not uncommon to hear a high-pitched sound from electronic devices -- e.g. from a camera's strobonar flash recharging for its next ready state -- these sounds are sometimes produced by a coil -- here's a link to an article on how to find and fix them in a computer: https://www.lifewire.com/fix-coil-whine-high-pitched-noise-4165184
Modern drills are controlled by PWM, and if you press the trigger just enough, you’ll hear the whine of this before the motor starts turning and drowning out the noise. I put mine next to my tablet with a free audio spectrum analyser app, and was able to pick out the 5 kHz tone - the ‘carrier’ frequency of the motor control circuit.
Likes anorlunda and Asymptotic
you guys are lucky.
As a kid i could hear the 15.575khz horizontal oscillator in my neighbor's TV set. They were all vacuum tubes back then, early 50's, and my family didn't have one.
as you age those sounds will disappear or get replaced by Tinnitus.
Nowadays I hear a constant whistle about 11khz and same loudness as normal conversation.
If you work in industry or shoot anything bigger than a 22 , wear ear protection. The damage is cumulative.
old jim
Likes Spinnor, Guineafowl, essenmein and 5 others
jim hardy said:
you guys are lucky.
old jim
I used to be able to hear the horizontal scanning frequency of TV receivers. Newer sets were more quiet but I could still hear them. Not so much anymore though. Age does that to a person. Hearing the horizontal scanning frequency from a neighbors set is pretty impressive. Either that or they had an exceptionally noisy TV.
Likes hmmm27, Steelwolf and jim hardy
I think in early 50's they were much noisier. We kids could walk around the block and tell from the sidewalk whose TV was on. If it was a friend's house we'd knock on the door and ask to come in for "Adventure Time" or "Hopalong Cassidy". This was ca 1950-1951.
Likes Spinnor, hmmm27, dlgoff and 2 others
LT72884 said:
...so i increased the voltage to the recommended specs...
If you increase a voltage on a component, it'll usually take more current => more power. More power means higher load on the power supply unit(s) of the device. Higher load sometimes means noise.
Try to re-set that voltage to the original below-spec level and check the noise. If it disappears then check if the actual power/current load on the power supplies is within the specifications (with both voltage settings).
It might not mean that there is an actual problem since some power supplies and switch mode devices can produce noise in their normal state too, but better check it anyway.
Try to check temperatures too. High load might mean unhealthy high temperature.
Do you hear the noise when you use a battery-powered device? All the devices you mentioned are powered by line voltage, I think.
Baby mice also make a high pitched sound when they miss their mother. One hot summer night I only knew something unusual was happening because I heard the occasional momentary sound of an HV breakdown arc. That was a fire hazard, but from which switching supply? Was it the computer monitor, the TV or the fax machine in the middle that had recently had it's supply flyback diode replaced?
So at 1AM I stood there, sweating at over +40°C, frozen in position, listening and waiting for the direction of the sound of an arc. That was when I was confronted, face to face with the tiger snake. The arcing sound was made by it's scales as it rounded the end of paper files. It was confused, hunting for the hundreds of baby mice that it could clearly hear in the switching supplies.
All reptiles are protected in Australia, so it died of hunger, indirectly. If it had lived it would now be describing how one night during a heatwave, it had been confronted by a naked man hunting mice. Analyse that one Freud.
Next day I looked in the freezer to confirm it had all been a nightmare, but there, curled up like a deep frozen pretzel was the snake. It rattled when I moved it. Who said we don't have rattle snakes in Australia.
  • Haha
Likes hmmm27, Tom.G, hutchphd and 4 others
WTH? All reptiles are protected in Australia? All reptiles in Australia are deadly venomous, mate. Including the tiger snake, BTW. As are all spiders, and those platypuses with venomous spines on their rear legs. Or else they're going to eat you and tuck you under a log underwater, like the crocodiles. Or do whatever those waterbuffaloes do to you. I saw Crocodile Dundee, so I know.
None of the snakes in Tasmania are poisonous.
You can eat all of them, except the venom glands.
@Mark Harder said reptiles in Tasmania are "venomous"; not "poisonous". If a venomous snake from Tasmania bites a poisonous frog from Brazil, both the reptile and the amphibian are apt to wind up dead from the encounter.
Likes Guineafowl
Yep, the snakes are venomous, but those said-to-be-delicious venom glands, they're poisonous.
Likes hmmm27 and sysprog
Related to High pitched noise with some elctronics
1. What causes high pitched noise with electronics?
The high pitched noise with electronics is typically caused by electromagnetic interference (EMI). This occurs when the electrical signals from different devices interfere with each other, resulting in the high pitched noise.
2. Can high pitched noise with electronics be harmful?
In most cases, high pitched noise with electronics is not harmful to humans. However, prolonged exposure to high levels of noise can lead to hearing damage. It is important to limit exposure to high pitched noise and use protective gear if necessary.
3. How can I reduce the high pitched noise with my electronics?
There are a few ways to reduce high pitched noise with electronics. One way is to use shielded cables and proper grounding techniques to minimize EMI. Another option is to use noise-cancelling headphones or speakers to block out the noise.
4. Is it normal for electronics to make high pitched noise?
It is normal for some electronics to make a slight high pitched noise, especially when they are turned on or performing intensive tasks. However, if the noise is loud or persistent, it could be a sign of a malfunction or EMI, and it is best to have the device checked by a professional.
5. Can high pitched noise with electronics be fixed?
In most cases, high pitched noise with electronics can be fixed by addressing the source of the interference. This could involve using different cables, repositioning devices, or using noise-reducing techniques. If the noise persists, it is best to consult a professional for further assistance.
  • General Discussion
  • Electrical Engineering
  • General Engineering
