High resolution = tiny words and graphics
In summary, a 21 inch CRT monitor is good for viewing pictures from a digital camera at 1920x1440, but the computer UI is too small at this resolution. Adjusting the text size in the display properties window only adjusts blocks of HTML text, and there is no way to implement a screen-wide "zoom" so text and objects appear the same size as they do when the monitor is set to 1024x768.
tony873004
143
I just got a 21 inch CRT monitor.
I like to set my monitor at 1920x1440 when looking at pictures from my digital camera. The screen is then almost large enough to show the entire picture without reducing the picture's sized and hence resolution.
But then everything else is tiny. For example, I'm in 1920x1440 mode now. I can comfortably read what I'm typing, but it would be nice if it were bigger. But the address bar is unreadable unless I move closer to the monitor. Adjusting Text Size in the view menu only adjusts blocks of HTML text, but doesn't affect web pages that use style sheets.
Choosing "Extra Large Fonts" in the display properties window only makes the words associated with icons larger, but not the icons themselves.
Is there some way to implement a screen-wide "zoom" so text and objects appear the same size as they do when my monitor is set to 1024x768, while still retaining all the crystal-clear resolution of 1920x1440.
It would be nice if the computer kept consistant sizing for all text and icons for all screen resolutions so I could keep my monitor at 1920x1440 all the time without purchasing reading glasses.
Computer science news on Phys.org
The obvious solution seems to be to switch back to a resolution with half as many pixels, rather than trying to make everything on the UI twice as big.
What's so hard about switching resolutions? If you don't like opening the Display control panel, there are plenty of third-party products that'll put a button on your taskbar, or associate a keystroke.
- Warren
Switching seems to re-arrange my desktop items, and requires fine adjustments in the monitor settings, such as horizontal size and position. It also takes about 30 seconds (am I that lazy?)
It just seems like there should be some utility where I can tell it that no matter what the resolution, the width of a desktop item should be 5% the width of the screen, the width of a 10 pitch font should be 0.5% the width of the screen, etc. So that all I notice by switching resolutions is that the pictures become clearer.
I didn't know about the 3rd party products. I guess that's why I post my questions here :) . Thanks Warren.
On systems that use display PostScript, like NeXT, it literally was that easy to switch screen resolutions without changing the size of on-screen UI elements.
However, Windows is just not that smart. Your best bet is just to tell Windows to use extra-large fonts, but that still won't make icons or other fixed-resolution graphical elements larger.
- Warren
You can make the icons larger i think. Right-click on your desktop -> properties ->in the appearance tag click advanced -> in the window that comes up, in the dropdown menu, select "icon" -> pump the size up. You should also play around with the other items in the dropdown menu to make your desktop more confortable.
I can imagine such a high resolution might slow down your computer a bit though.
Windows does not use vector based graphics for the UI yet, so the bitmaps for the fonts and for the icons get smaller with higher resolutions.
Related to High resolution = tiny words and graphics
1. What does "high resolution" mean?
High resolution refers to the level of detail or clarity in an image, typically measured in pixels per inch (ppi) or dots per inch (dpi). The higher the resolution, the more pixels or dots are used to create the image, resulting in a clearer and more detailed picture.
2. Why do tiny words and graphics appear in high resolution?
When an image is displayed in high resolution, it means that a larger number of pixels or dots are used to create a smaller area. This results in a higher level of detail, making it possible to display tiny words and graphics that would otherwise appear blurry or illegible in lower resolutions.
3. Is high resolution always better for images?
Not necessarily. While high resolution can be beneficial for displaying small details, it also requires more memory and processing power. For certain images, such as those intended for web use, a lower resolution may be more suitable to ensure faster loading times and better compatibility across devices.
4. Can I change the resolution of an image?
Yes, the resolution of an image can be changed using image editing software. However, keep in mind that increasing the resolution of an image will not improve its quality if the original image is low resolution. It is also important to note that decreasing the resolution may result in a loss of detail and clarity.
5. Are there different types of high resolution?
Yes, there are different types of high resolution depending on the medium in which the image will be displayed. For example, print resolution is typically measured in dpi, while screen resolution is measured in ppi. It is important to use the appropriate resolution for the intended medium to ensure the best quality output.
  • Computing and Technology
  • Science Fiction and Fantasy Media
  • Feedback and Announcements
