MHB High school inequality 5 abc+acb+bca≥a+b+c.
The discussion focuses on proving two mathematical inequalities without using specific methods like AM-GM or contradiction. The first inequality states that the sum of the products of variables divided by another variable is greater than or equal to the sum of the variables themselves. The second statement asserts that if two variables are each less than or equal to the other, they must be equal. Participants express confusion about the relevance of the squeeze theorem to these proofs, seeking clarification on its application. The conversation highlights the challenges in understanding and proving these mathematical concepts.
solakis1
1)Prove without using AM-GM :$$\frac{ab}{c}+\frac{ac}{b}+\frac{bc}{a}\geq a+b+c$$...... a,b,c >02) Prove without using contradiction :
$$a\leq b\wedge b\leq a\Longrightarrow a=b$$
Mathematics news on Phys.org
my solution:
(1)$\times abc$
we have to prove :$(ab)^2+(bc)^2+(ca)^2>(abc)\times (a+b+c)=a^2bc+b^2ca+c^2ab$
for $(A-B)^2=A^2-2AB+B^2$
$\therefore A^2+B^2>2AB---(3)$
likewise $B^2+C^2>2BC---(4)$
$C^2+A^2>2CA---(5)$
(3)+(4)+(5) we have $A^2+B^2+C^2>AB+BC+CA$
let $A=ab,B=bc,C=ca$
and the proof is done
(2)The statement A ∧ B is true if A and B are both true; else it is false.(definition of ∧:logical conjunction)
by using squeeze theorem we get:
Albert said:
my solution:
(1)$\times abc$
$C^2+A^2>2CA---(5)$
Sorry , but what is the squeeze theorem ??
solakis said:
I am sorry but i fail to see the connection.
If you would care to elaborate a bit more
for example :
since $cos \,x\leq \dfrac {sin\, x}{x}\leq 1$
so $ \dfrac {sin \,x}{x} $ approaches 1 as x approaches 0
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
