High Temperature Dielectric Coating
In summary, the conversation revolves around finding a dielectric coating that can be used in a high temperature steam environment for a specific application involving a coated acupuncture needle. The coating must be able to be applied in a thin layer through a dipping process, have a low viscosity, and be resistant to cracking and adhere to stainless steel needles. Suggestions for possible coatings include those made by Aremco, Parylene, and anodization. The choice of material for the needle is limited due to its use in acupuncture and the need for it to be accepted by the human body. The ultimate goal is to use the coated needle as a sensor to detect the interfaces of bubbles in a high temperature flowing steam environment.
DanatAMFL
I'm looking for some sort of dielectric coating that can be used at high temperatures. I'm working on trying to create a voltage point charge in a high temperature steam environment using a coated accupuncture needle. The goal is to be able to coat the needle thinly and uniformly, leaving only the very tip of the needle exposed and electrically conductive with the rest completely insulated. Therefore I'm looking for something that can be applied in extremely thin coatings (~.05mm thickness) through a dipping process, meaning it has to have a low enough viscosity (~200 cP) to achieve this thickness. The coating should be resistant to cracking once cured and be able to adhere to stainless steel accupuncture needles. The steam environment that the coating and needle will be subjected to will have temperatures ranging up to 500 deg C.
Do you have any suggestions?
So far I have discovered a few coatings made by Aremco (SGC4000 and GC4000) that seem like they may work. Has anyone had any experience with these coatings?
Thanks!
Thanks!
Welcome to the PF.
Parylene looks like it's good up to 350C, but it sounds like that isn't enough for your application:
http://en.wikipedia.org/wiki/Parylene
You might give them a call to see if they have something that could work for you.
What about anodic oxidation, instead of dipping? With a needle of tantalum you get a good insulator.
berkeman:
We have looked into the teflon coatings and it seems as though the coating is a little too thick and we cannot shape it in the desired way.
Enthalpy:
Would it be possible to anodize a needle that small? The accupuncture needles have a diameter ~120 microns. Also, how would we control the process so that the tip could be exposed?
120µm diameter is no worry, and leave the tip outside the anodizing bath to keep it naked, or cover it with some insulating varnish that you strip afterwards.
BUT... In acupuncture, your choice of materials is very limited! It must be accepted by the human body. This should be checked first, as it restrict the choice more than other constraints. Tantalum maybe? Titanium yes. Niobium? Beware the detailed alloy composition matters both for medicine and for anodization.
Or: use a stainless steel alloy or similar, like cobalt-chromium. Anodize the shaft, cover the tip so it won't develop a thick oxide layer when you put the needle in 500°C vapour.
Do you have a wide choice of tip materials for acupuncture? A metal that stays clean and conductive in 500°C vapour is difficult: gold, platinum, maybe molybdenum...
I'm not sure that anodizing will be an option for us. We are not looking to use the needles for accupuncture. We are trying to develop a sensor that can detect the interfaces of bubbles in a high temperature flowing steam environment. We do this currently in a flowing air-gas mixture at room temp by using a urethane coated needle with the tip exposed (conductive) and applying a voltage to the water. In this way, we can see when (and, due to the size and known location of the exposed tip, where) a bubble interface passes the sensor due to the drop in voltage of the sensor while it is inside the bubble (in the non-conductive air). We are looking to do the same thing, or something similar in the high temperature environment.
Thanks!
You could plate titanium on the needle and then use medical titanium anodizing to make the insulating layer. You would prevent the tip from being coated by simply not submerging it in the solution along with the rest of the needle.
-Gene
Why no anodizing?
Well, you could try vacuum vapor deposition of all sorts of ceramic materials. Titanium Nitride, Silicon Carbide, etc. That's how they coat drill bits and cutting tools. Just remember to cover the tip somehow so it doesn't get coated.
At 500C, polymers are just out of the question. The only way is some sort of ceramic dielectric. And simplly dipping isn't going to work with ceramic coatings.
Related to High Temperature Dielectric Coating
1. What is high temperature dielectric coating?
High temperature dielectric coating is a type of protective coating that is designed to withstand extreme temperatures without losing its insulating properties. It is commonly used on surfaces that are exposed to high temperatures, such as in industrial or aerospace applications.
2. How does high temperature dielectric coating work?
High temperature dielectric coating works by creating a barrier between the surface it is applied to and the surrounding environment. This barrier prevents heat from transferring through the coating, keeping the surface temperature lower and protecting it from damage.
3. What materials are typically used in high temperature dielectric coatings?
Silicon carbide, aluminum oxide, and zirconium oxide are commonly used materials in high temperature dielectric coatings. These materials have high thermal conductivity and can withstand high temperatures, making them ideal for protecting surfaces in extreme environments.
4. What are the benefits of using high temperature dielectric coating?
High temperature dielectric coating offers several benefits, including thermal insulation, protection against corrosion and oxidation, and improved durability and longevity of the coated surface. It also helps to reduce energy consumption and maintenance costs.
5. Is high temperature dielectric coating environmentally friendly?
Yes, high temperature dielectric coating is environmentally friendly as it does not contain harmful chemicals or emit volatile organic compounds (VOCs). It is also highly resistant to chemical and UV degradation, making it a long-lasting and sustainable solution for protecting surfaces in high temperature environments.
  • Materials and Chemical Engineering
9K
  • Astronomy and Astrophysics
  • Earth Sciences
