Highschool Diving board distortion problem
In summary, a physics teacher with a mass of 80.0 kg stands on a diving board with a length of 2.0 m. The board has a distortion of 22.5 cm when the teacher stands on it. When the teacher's noisy neighbor stands on the board, the distortion increases to 32.0 cm. Using Hooke's law, the mass of the neighbor can be calculated to be approximately 113.78 kg.
Soccerface
A physics teacher (mass 80.0 kg) stands at the end of his 2.0 m long diving board. The distortion of the free end is 22.5 cm. when his noisy neighbor comes over and stands at the end he distorts it by 32.0 cm. what is the mass of the noisy neighbor?
Mass of teacher = 80.0 kg
Force = 780N
L = 2.0m
Distortion of Teacher = 22.5cm
Distortion of neighbour = 32.0cm
Mass of Neighbour = ?
Cannot figure out equation.
22.5cm / 80.0 kg = 0.28125 cm/kg
Diving board can handle 0.28125 cm/kg
So if neighbour distorts 32.0 cm
32.0cm / 0.28125cm/kg = 113.777777kg
Our teacher never gave us any equations or sample problems to go off of, so I'm just winging it, Please help!
Welcome to PF Soccerface!
The only way I can think of to approach this problem is to assume the the board is springy i.e. it acts like a spring under bending, in the sense that the more you bend it downward, the harder it pushes up on you (trying to unbend). Maybe you are meant to assume that Hooke's law applies in this case, and therefore the force is proportional to the displacement, i.e. it's equal to some constant k, times the displacement? If so, you should be able to solve for k given the first pair of force and displacement, and that k will then allow you to solve for the second force given the second displacement.
In which case, your answer is correct. Force is proportional to displacement for materials that obey Hooke's law.
Related to Highschool Diving board distortion problem
1. What is the Highschool Diving board distortion problem?
The Highschool Diving board distortion problem refers to the phenomenon where a diving board appears to bend or distort when viewed from a certain angle. This is caused by the refraction of light as it passes through the water and then through the air.
2. Why does the diving board appear distorted?
The diving board appears distorted due to the refraction of light. When light travels from water to air, it changes speed and direction, causing the object (in this case, the diving board) to appear bent or distorted.
3. Is the Highschool Diving board distortion problem dangerous?
No, the distortion of the diving board does not pose any danger to the diver. It is simply a visual effect caused by the refraction of light and does not affect the structural integrity of the diving board.
4. Can the Highschool Diving board distortion problem be fixed?
The distortion of the diving board cannot be completely eliminated, as it is a natural optical phenomenon. However, certain measures such as adjusting the angle of the diving board or using polarized sunglasses may reduce the distortion.
5. Does the Highschool Diving board distortion problem affect the accuracy of the dive?
No, the distortion of the diving board does not impact the accuracy of the dive. Divers are trained to focus on the end of the board and not be affected by any visual distortions.
21K
12K
10K
