Holographic principle, mathematical universe & dimensional reduction
In summary, the holographic principle suggests that the observable universe can be represented as a two-dimensional surface and that the universe itself is a mathematical object. However, this principle does not always apply and there are specific physical systems that cannot be fully described by a lower dimensional system. Additionally, there needs to be more than just a boundary for the holographic principle to work and even the simplest test shows that it may not be applicable.
tobiasnas
If the holographic principle says that the the observable universe could be represented as a two dimensional surface, and we accept the idea that the universe is itself a mathematical object, and cantor showed that we could in some cases represent higher dimensional sets within lower dimensional sets, then could we say that the universe is a one dimensional string, and could we also say that if it were a finite random string of arbitrarily large size then within it there would be apparently nonrandom strings of arbitrary length?
Space news on Phys.org
Holography isn't always possible. There are some specific physical three-dimensional systems whose behavior can be captured by instead describing them as a different two-dimensional system.
At a bare minimum, for holography to function there needs to be a boundary. For example, the event horizon of a black hole acts as a sort of boundary separating the interior of the black hole from the exterior. It may be the case that with quantum gravity, we can fully and completely describe the interior of the black hole simply by talking about the state of its event horizon.
But that event horizon doesn't itself have a boundary: if it did, it couldn't fully-enclose the black hole. So there is no one-dimensional surface that can possibly represent the behavior of the event horizon.
You need more than just a boundary for the holographic principle to apply, but this shows that it fails even the simplest test.
Related to Holographic principle, mathematical universe & dimensional reduction
1. What is the holographic principle?
The holographic principle is a concept in physics that suggests all the information in a particular volume of space can be represented on a lower-dimensional surface. This means that a three-dimensional object can be represented by a two-dimensional surface, similar to how a hologram works.
2. How does the holographic principle relate to the mathematical universe?
The holographic principle is closely related to the mathematical universe hypothesis, which posits that our physical reality is fundamentally based on mathematical equations. The holographic principle suggests that the universe can be described and understood through mathematical principles and equations.
3. What is dimensional reduction?
Dimensional reduction is the idea that our three-dimensional world can be reduced to a lower-dimensional space through the use of mathematical principles. This can be seen in the holographic principle, where a three-dimensional space can be represented on a two-dimensional surface.
4. How does the holographic principle potentially explain the mysteries of black holes?
The holographic principle has been used to explain the paradox of information loss in black holes. According to this principle, all the information that falls into a black hole is encoded on the event horizon, the two-dimensional surface surrounding the black hole. This means that the information is not lost, but rather preserved in a lower-dimensional form.
5. What are some practical applications of the holographic principle?
The holographic principle has been applied in various fields such as quantum gravity, string theory, and black hole physics. It has also been used in computer science to improve data storage and compression techniques. Additionally, some research suggests that the holographic principle could potentially be used in quantum computing and other advanced technologies in the future.
  • Beyond the Standard Models
  • Cosmology
  • Astronomy and Astrophysics
