Holographic Principle question
In summary: It is just that the physical manifestation of the book is.In summary, the information in a book that is dropped into a black hole is retained and comes out as Hawking Radiation. There is a 66.666…% chance that the information is coming out of the left eye of the person describing the summary.
incompetence123
So I've been looking up things on the Holographic Principle for a while now, but there's still a few questions I have.
As I understand it, the Principle says that if I drop a book into a black hole the book's information would be 3D inside the black hole and it would also be 2D on the event horizon.
My question is, are there two books one 3D and the other 2D? Or is there just one book that is 2D and the 3D version is a projection that somehow emerges from the surface? In other words, when I drop a book into a black hole, is a copy created when it passes the event horizon or is there just one book in the entire system?
If I'm unclear about this let me know. Also, I'm not a physicist so please keep answers layman.
No, the book inside the BH has its information destroyed as it goes into the singularity. Well, that may not be quite right. The BOOK is destroyed but Hawking says the information is retained and comes out as Hawking Radaition.
The 2D representation embodied in the holographic principle is, as far as I am aware, a mathematical fiction (strongly believed in by some, e.g. Lenard Suskind, who came up with the idea) that has no physical reality but which maintains the concept that information cannot be lost in the universe.
I am a layman on this as well, so my opinion should be taken with a large grain of salt, and I readily admit that I think the concept is ridiculous.
The black hole situation is one thing, because the event horizon of a BH, which not being a physical thing, IS a place where physical things happen (light emitted there, heading away from the singularity, just STAYS there, locally moving at c but globally hovering right there).
On the other hand, the holographic principle also says (assuming that I understand it properly) that the information in the observable universe, for example, is contained on the surface of the sphere that defines the observable universe but that just seems ridiculous because the "surface" of the OU really IS just a mathematical representation of a place in space where nothing is happening. There is no physical reality to it. Also, MY observable universe has a completely different representational sphere than your OU, the two having centers that are at my right eyeball and your right eyeball (and this is assuming someone has poked our our left eyes).
I thought you needed physical reality to have information. So the event horizon has no physical reality? How does the information exist on the horizon anyway? And is there a connection of some kind between the information on the horizon and the physical book inside? If so, what kind?
I was also wondering how Hawking Radiation captured the information from the black hole (especially if there is no physical reality to
capture). I get how black holes evaporate (on a layman's level), but not how the information is saved.
The whole "information war" between Hawking and Susskind is way over my head and the Holographic Principle makes no sense to me so maybe someone who understands it better and believes in it will jump in and help you out.
phinds said:
"observable universe" --- a sphere of approximately 47 Billion light years radius, centered on your left eyeball.
OCR said:
Nothing at all, however... there is a 66.666…% chance it's his right eyeball.
Lol... Ah, a work around that works... :oldeyes:
You're quite right... :oldeyes:
I think that the book in the black hole is not a good example. if we believe that information cannot be destroyed we may accept that the number of copies of a same information can decrease.
The book has an author outside the BH or is on internet or somewhere else.
I cannot understand your point at all and I think you misunderstand the issue. The existence or non-existence of an author outside the black hole has zero to do with whether or not information is conserved when something falls into a black hole. The information being discussed has nothing to do with anything that didn't fall into the black hole.
the information falling in a black hole does not disappear if i have it in my library!
There is only a problem if there is no copy.
As I thought, you completely miss the point of the issue. I have already explained this in post #8. If you wish to believe in your own version of reality, that's fine, but it is the way it is. You misunderstand the concept of "information" in terms of physics and are incorrectly applying a very narrow English-language definition which excludes just about everything having to do with the book.
A book is a macroscopic object on which you can read text or binary things like 1101
I have a de finition of information. it is answer to questions. If i have two copies of a text i can find the anwer in one of those. If i concatenate them i get 11011101 which has the sameShannon information as 1101. if i throw one of the book in a Black Hole the remainig text has still the same information. Of course paper and ink is lost in the BH. I do not think that you confuse the media and the information. Maybe you think that i use a classical notion of information which "miss the point" and think that the answer is in quantum information.
At the end you will have to explain how non vanishing classical information is recovered.
I give you a definition of information as yes/no answers to a question which is asked to multiple copies of the same thing.
Now it's your turn to define what is quantum information.
Is it local? where is it in a Bell pair? Does not hesitate to be rigorous or technical.
Thanks.
I can't give you a rigorous definition but basically, it is everything about an object. The type, state, and arrangement of all the atoms that make it up for example. The "information" that you are talking about is utterly trivial by comparison, in terms of volume of information. And it is about THAT object, not some other macroscopically similar object.
That's a good explanation of what information is. You can skip to 1:30 if you want.
Seriously? UGH. That guy is a rambling bore more interested, apparently, in talking about himself than about science.
FAQ: Holographic Principle question
What is the Holographic Principle?
The Holographic Principle is a theory in physics that suggests the information contained in a volume of space can be represented on a lower-dimensional surface, similar to a hologram. This principle was first proposed in 1993 by physicist Leonard Susskind and has since been a subject of much research and debate.
How does the Holographic Principle relate to black holes?
The Holographic Principle is often applied to black holes, as they are considered to be one of the most extreme examples of concentrated information in a small space. According to the theory, all of the information about the objects that fall into a black hole is encoded on its event horizon, the boundary of the black hole's gravitational pull.
What is the significance of the Holographic Principle?
The Holographic Principle has significant implications for our understanding of the universe and its fundamental laws. It suggests that the three-dimensional world we perceive is actually a projection of information stored on a two-dimensional surface. This could potentially help physicists reconcile the discrepancies between quantum mechanics and general relativity.
Has the Holographic Principle been proven?
While there is evidence that supports the Holographic Principle, it has not been definitively proven. Scientists are still working to understand the implications of the principle and how it may fit into our current understanding of the universe.
What are some criticisms of the Holographic Principle?
One of the main criticisms of the Holographic Principle is that it is difficult to test experimentally. Additionally, some physicists argue that the principle is not necessary to explain the laws of physics and may be an unnecessary complication. Others question the validity of the principle and its applicability to all areas of physics.
