lurch85
- 33
Looking to make a heat exchanger so that I can have a less than adequately antifreeze treated water (easily over 750 gallons, so very expensive) from the outdoor wood boiler constantly circulating through a water jacket, and heat an adequately treated fluid (glycol treated water) and can turn the circulating pumps off to the garage, which contains underfloor (concrete) and some modine style hot water to air heat exchangers.
my plan is to use some old air conditioner coils and place inside a water jacket.
assume the radiator coils to be 3/8 diameter spaced 2 inches apart with a 2 inch square of aluminum per 1/8 inch of length.
thickness of tubing and aluminum fins unknown at this time and I'm hoping negligible (make your own assumptions if you would)
would like to see the math for anyone that feels up to it.
im hoping to get an answer in the form of something like (x btu per foot of tubing with 10 gallon per minute of water supply (to the both the water jacket and heating coils in the garage)and at a temperature difference of 150 degrees)
feel free to change, ask questions, or add anything you may see as far as variables go... Adding as much information as I can think of to make it easier
If questions are asked, I will add to the original question as needed and make additions in bold/underlined and red
respectfully submitted
