Homeomorphism and project space
In summary: Consider the map f : X → PRn−1 defined by f(x) = [x], where [x] is the equivalence class of x under the relation RG. This map is well-defined since if x ~ y, then [x] = [y]. It is also continuous since the projection map p : X → X/RG is continuous, and the composition of continuous maps is continuous. Since every point in X/RG is of the form [x] for some x ∈ X, then f is surjective. To show that it is injective, let x and y be two distinct points in X such that f(x) = f(y). Then [
rainwyz0706
36
1. (1) (a) Let X be a topological space. Prove that the set Homeo(X) of home-
omorphisms f : X → X becomes a group when endowed with the binary operation f ◦ g.
(b) Let G be a subgroup of Homeo(X). Prove that the relation ‘xRG y ⇔ ∃g ∈ G such
that g(x) = y ’ is an equivalence relation.
(c) Let G and RG be as in (b), and let p : X → X/RG be the quotient map. Prove that for every U open in X , p(U ) is open in X/RG .
2.(i) Let X = Rn \ {O} , n ≥ 2 , and let G be the subgroup of Homeo(X) composed of the
maps gλ (x) = λx. Prove that X/RG is the real projective space P Rn−1 .
(ii) Prove that the graph of the relation RG described in (i) is closed.
(iii) Prove that P Rn−1 is Hausdorff.
The setup was pretty straightforward. Could anyone give me some hints how to deal with later ones? Any input is appreciated!
1. (a) To show that Homeo(X) is a group, we need to show that it is closed under composition and has an identity element. To show closure under composition, let f and g be two homeomorphisms in Homeo(X). Then, their composition, f ◦ g, is also a homeomorphism since it is the composition of two continuous functions. To show that there is an identity element, consider the identity map, id : X → X, which is a homeomorphism and is the identity element of Homeo(X). (b) To show that the relation 'xRG y ⇔ ∃g ∈ G such that g(x) = y' is an equivalence relation, we need to show that it is reflexive, symmetric, and transitive. To show that it is reflexive, let x be an arbitrary element of X. Then there exists the identity element id ∈ G such that id(x) = x, so xRGx. To show that it is symmetric, let x and y be elements of X such that xRGy. Then there exists a g ∈ G such that g(x) = y. Since G is a subgroup of Homeo(X), then g-1 ∈ G. Thus, g-1(y) = x, so yRGx. To show that it is transitive, let x, y, and z be elements of X such that xRGy and yRGz. Then there exist g, h ∈ G such that g(x) = y and h(y) = z. Thus, g ◦ h ∈ G, and (g ◦ h)(x) = z, so xRGz. Therefore, the relation is an equivalence relation. (c) Let U be an open subset of X. Then for any x ∈ U, there exists an open ball Bx around x such that Bx ⊂ U. Since p is a continuous map, then p(Bx) is an open ball around p(x) in X/RG. Thus, p(U) = {p(x) | x ∈ U} is open in X/RG. 2. (i) To show that X/RG is the real projective space PRn−
FAQ: Homeomorphism and project space
What is a homeomorphism?
A homeomorphism is a continuous and bijective (one-to-one and onto) map between two topological spaces that has a continuous inverse. In simpler terms, it is a function that preserves the shape and structure of a space.
How is a homeomorphism different from an isomorphism?
A homeomorphism is a type of topological isomorphism, meaning it preserves the topological properties of a space such as connectedness and compactness. However, an isomorphism also preserves algebraic properties, such as group operations, which a homeomorphism does not necessarily preserve.
What is the project space in a homeomorphism?
The project space, also known as the quotient space, is the resulting space after applying a homeomorphism to a given space. It is created by identifying points in the original space that are considered equivalent under the homeomorphism.
Can a homeomorphism exist between two spaces with different dimensions?
No, a homeomorphism can only exist between spaces with the same dimensionality. This is because a homeomorphism must preserve the number of dimensions in order to preserve the topological properties of a space.
How is a project space useful in mathematics and science?
Project space is useful in providing a new way of looking at and understanding a space by identifying its equivalent points. This can help simplify complex spaces and make them easier to study, as well as provide insights into the structure and properties of a space.
