Homeomorphisms and ##\mathbb{R}##
  • I
  • Thread starter kent davidge
In summary, it is not possible to construct a continuous bijection between the usual topology on ##\mathbb{R}## and the discrete topology on ##\mathbb{R}##, therefore these two topological spaces are not homeomorphic.
kent davidge
933
56
Is it hard to show that ##\mathbb{R}## with the usual topology and ##\mathbb{R}## with the discrete topology are not homeomorphic? I'm reasoning this way: in the discrete topology there are every possible subsets of ##\mathbb{R}##, which includes those with just one element of the type ##\{x \}##. There cannot be bijection from an open subset of the usual topology, which requires a distance greater than zero, and a set with just one element. Is this sufficient in proving that these two topological spaces are not homeomorphic?
You already said it. Assume a homeomorphism ##f \, : \,\mathbb{R}_E \longrightarrow \mathbb{R}_D## from the Euclidean reals to the discrete reals. Now ##\{x\} \subseteq \mathbb{R}_D ## is open. Now what is required for ##f^{-1}(\{x\}) \subseteq \mathbb{R}_E\,##?
To be open?
Yes, ##f## has to be continuous, i.e. pre-images of open sets have to be open. But open sets in Euclidean ##\mathbb{R}_E## contain at least two elements or none. Either way, if ##f## is a bijection, we have only one available for ##f^{-1}(\{x\})##.
Likes kent davidge
Related to Homeomorphisms and ##\mathbb{R}##
What is a homeomorphism?
A homeomorphism is a function between two topological spaces that is continuous, bijective, and has a continuous inverse. This means that a homeomorphism preserves the topological structure of a space, such as the number of connected components, the existence of holes, and the relative distances between points.
What is the significance of homeomorphisms in mathematics?
Homeomorphisms are important in mathematics because they allow us to study topological spaces by looking at simpler, more familiar spaces. By finding a homeomorphism between a complicated space and a simpler one, we can use our knowledge of the simpler space to make conclusions about the more complex one.
What is the difference between a homeomorphism and an isomorphism?
A homeomorphism is a topological concept, while an isomorphism is an algebraic concept. Homeomorphisms preserve the topological structure of a space, while isomorphisms preserve the algebraic structure of a space.
How do you prove that two spaces are homeomorphic?
To prove that two spaces are homeomorphic, you need to find a function between them that meets the criteria of a homeomorphism. This involves showing that the function is continuous, bijective, and has a continuous inverse. You can also show that two spaces are homeomorphic by finding a set of homeomorphic maps between them.
What is the relationship between homeomorphisms and ##\mathbb{R}##?
Homeomorphisms are closely related to ##\mathbb{R}##, as ##\mathbb{R}## is often used as a benchmark for topological spaces. Many topological spaces are compared to ##\mathbb{R}## to determine if they are homeomorphic. Additionally, homeomorphic spaces often share similar properties with ##\mathbb{R}##, such as being connected and simply connected.
  • Topology and Analysis
