MHB Homework: Bisectors and Intersection Points of Straight Lines
One of the angle bisectors of the lines defined by the equation ax² + 2hxy + by² = 0 will intersect at the point of intersection of the lines represented by ax² + 2hxy + by² + 2gx + 2fy + c = 0 if the condition h(g² - f²) = fg(a - b) holds. The intersection point of the lines is identified as the center of the conic, given by specific coordinates. The angle bisector equation is hx² + (b - a)xy - hy² = 0. Substituting the intersection point into the bisector equation leads to a polynomial that simplifies to a product of factors. The condition ab - h² is always negative for conics consisting of two straight lines, confirming that the other factor must equal zero, thus proving the statement.
Suvadip
Show that one of the bisectors of the angles between the pair of straight lines ax2+2hxy+by2=0 will pass through the point of intersection of the straight lines ax2+2hxy+by2+2gx+2fy+c=0 if
h(g2-f2)=fg(a-b)
Please help
Mathematics news on Phys.org
suvadip said:
Show that one of the bisectors of the angles between the pair of straight lines $ax^2+2hxy+by^2=0$ will pass through the point of intersection of the straight lines $ax^2+2hxy+by^2+2gx+2fy+c=0$ if $h(g^2-f^2)=fg(a-b).$
If the conic $ax^2+2hxy+by^2+2gx+2fy+c=0$ consists of two straight lines, then the point of intersection of those lines is the centre of the conic, which is given here to be the point $$\left(\frac{hf-bg}{ab-h^2},\frac{hg-af}{ab-h^2}\right).\qquad(1)$$ The equation of the pair of angle bisectors of the lines $ax^2+2hxy+by^2=0$ is given here to be $$hx^2 + (b-a)xy -hy^2 = 0.\qquad(2)$$ Substitute the point (1) into the equation (2), and you get $$h(hf-bg)^2 + (b-a)(hf-bg)(hg-af) -h(hg-af)^2 = 0.$$ Multiply that out, and you will find that some of the terms combine or cancel. The remaining terms can be factorised to give you $$(ab-h^2)(g^2h-f^2h + bfg - afg)=0.$$ But $ab-h^2\ne0$ because that expression is always negative for a conic consisting of two straight lines (see http://www.mathhelpboards.com/f11/pair-straight-lines-3646/). Therefore the other factor must be zero, which gives the required solution.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
