Homework help (normal and tangential coordinate problem)
In summary, the problem involves a baseball player releasing a ball with a velocity of 100 ft/sec at an angle of 30 degrees. The goal is to determine the radius of curvature of the ball's trajectory just after release and at the apex. The only acceleration acting on the ball is due to gravity, and using the equations a_n = v^2 / ρ *cos(θ) and a_n = v^2 / ρ *sin(θ), the values for ρ are calculated to be 358.6 ft and 100 ft, respectively. The time rate of change of speed is also calculated to be -32.2 ft/s^2 just after release and 0 ft/s^2 at the apex
nineeyes
Problem : A baseball player releases a ball with [tex]v_0= 100 ft/sec[/tex] at an angle of [tex]\theta= 30 degrees[/tex]. Determine the radius of curvature of the trajectory (a) just after release and (b) at the apex. For each case compute the time rate of change of the speed.
I really wasn't sure how to do the problem, so I sort of just guessed at a lot of things. So any help would be great. But this is what I did.
I assumed the only acceleration after the ball was thrown was due to gravity.
so I got
[tex] a_n=-32.2*cos(30)[/tex] [tex]a_t=-32.2*sin(30)[/tex]
then I used [tex] a_n=\frac{v^2}{\rho}[/tex] to solve for the curvature [tex]\rho[/tex] for when the ball was just released I got [tex]\rho = 358.6 ft[/tex] . Then I used [tex]\beta'=\frac{100}{\rho}[/tex] to solve for the angular rate.
I wasnt sure on how to solve (b) so I just assumed that the angle between [tex]\theta[/tex] and the x- axis would be 0 degrees since the apex is the highest point and I guessed that would be when the ball would stop moving up and start going down.
So I got
[tex]a_n = -32,2 ft/s^2[/tex]
then used
[tex]a_n=v*\beta'[/tex] to solve for v at the apex using the the angular rate i got earlier for beta'.
I got [tex]v=115.4ft/s[/tex]
then using the v and [tex]a_n[/tex] I solved for [tex]\rho[/tex] using the equation [tex] a_n=\frac{v^2}{\rho}[/tex]
I got [tex]\rho= 413 ft[/tex]
I'm definitely not confident with this answer, it's the first time I've done a problem like this, and I'm not sure if everything I did and assumed was legal.
Thanks in advance for any help.
Hi there! Thanks for sharing your approach to the problem. Let's go through it step by step and see if we can improve on your solution.
First, you correctly identified that the only acceleration acting on the ball after it is released is due to gravity. So your values for the normal and tangential accelerations are correct.
Next, you used the equation a_n = v^2 / ρ to solve for the radius of curvature, which is a good approach. However, there is a small error in your calculation. The correct equation is a_n = v^2 / ρ *cos(θ), where θ is the angle between the velocity vector and the x-axis. In this case, θ = 30 degrees, so the correct value for ρ is 358.6 ft, as you calculated.
For part (b), you correctly identified that the angle between θ and the x-axis at the apex is 0 degrees. However, your approach for calculating the radius of curvature is incorrect. The correct equation is a_n = v^2 / ρ *sin(θ), where θ is the angle between the velocity vector and the x-axis. Since θ = 0 degrees, the value for ρ is 100 ft, which is the same as the speed of the ball at the apex.
To calculate the time rate of change of speed, we can use the equation a_t = dv/dt, where a_t is the tangential acceleration and v is the speed. We know the value for a_t from the beginning, and we can use the value for v that we calculated in part (b). So the time rate of change of speed just after release is -32.2 ft/s^2, and at the apex it is 0 ft/s^2.
I hope this helps! Let me know if you have any other questions or if you would like me to explain anything in more detail. Good luck with your future problem-solving!
Hi there! Thank you for reaching out for help with this problem. Let's go through it step by step to make sure we understand the concepts and calculations involved.
Firstly, it is correct to assume that the only acceleration acting on the ball after it is released is due to gravity, as there are no other external forces acting on it.
Next, let's define our coordinate system. We can use a Cartesian coordinate system, with the x-axis being the horizontal direction and the y-axis being the vertical direction. The initial velocity, v_0, can be broken down into its x and y components as v_{0x}=v_0cos(\theta) and v_{0y}=v_0sin(\theta).
(a) To determine the radius of curvature just after release, we can use the equation a_n=\frac{v^2}{\rho}, where a_n is the normal acceleration and \rho is the radius of curvature. We can substitute in the values we know: a_n=-g=-32.2 ft/s^2 and v=v_0=100 ft/s. Solving for \rho, we get \rho=\frac{v^2}{a_n}=\frac{100^2}{32.2}=310.56 ft.
To find the time rate of change of speed, we can use the equation a_t=\frac{dv}{dt}, where a_t is the tangential acceleration. Since there is no tangential acceleration in this case, the time rate of change of speed is 0 ft/s^2.
(b) To determine the radius of curvature at the apex, we can use the same equation as before, but with the values at the apex instead. At the apex, the velocity will be purely horizontal, so v=v_{apex}=v_{0x}=v_0cos(\theta)=86.6 ft/s. Using the same equation, we get a_n=\frac{v^2}{\rho}=-g=-32.2 ft/s^2. Solving for \rho, we get \rho=\frac{v^2}{a_n}=\frac{86.6^2}{32.2}=232.48 ft.
To find the time rate of change of speed at the apex, we can use the same equation as before, but with the tangential acceleration being due to the change in vertical velocity. As the ball reaches the apex, its vertical velocity
Related to Homework help (normal and tangential coordinate problem)
1. What is a normal and tangential coordinate problem?
A normal and tangential coordinate problem is a type of mathematical problem that involves finding the normal and tangential components of a vector in a particular coordinate system. This is commonly used in physics and engineering to analyze the motion of objects.
2. How do I solve a normal and tangential coordinate problem?
To solve a normal and tangential coordinate problem, you will need to first identify the vector in question and its components. Then, you can use mathematical equations and trigonometric functions to find the normal and tangential components in the given coordinate system. It is important to carefully label and draw diagrams to visualize the problem.
3. What are some real-world applications of normal and tangential coordinate problems?
Normal and tangential coordinate problems are commonly used in fields such as physics, engineering, and mechanics. They can help analyze the motion of objects in circular or curved paths, such as the orbit of a satellite or the motion of a rollercoaster. They can also be used to calculate forces and acceleration in these scenarios.
4. Are there any common mistakes to avoid when solving normal and tangential coordinate problems?
One common mistake to avoid is using the wrong coordinate system. It is important to carefully consider and understand the given scenario to determine the appropriate coordinate system to use. Another mistake to avoid is mixing up the normal and tangential components, as they have different mathematical equations and should be carefully labeled.
5. Are there any helpful tips for solving normal and tangential coordinate problems?
It can be helpful to draw diagrams and label all given information before attempting to solve the problem. It is also important to double-check all calculations and make sure they are consistent with the given scenario. Practice and familiarity with trigonometric functions and vector analysis can also greatly aid in solving these types of problems.
