Blond Arrow
- 2
Here is the problem:
The electron concentration in a region of silicon depends linearly on depth with concentration of 5x10^15 cm^-3 at surface (x=0) and 10^15 cm^-3 at depth of x=500nm. If the vertical electron current density in this region is constant at Jn=100 A/cm^2, calculate the electric field near x=500nm. assume that the mobility is constant at 1250cm^2/Vs.
If anyone can at least explain the meaning of each value written in the problem and the formula that can be used to solve this problem ..
Thank you...
Thank you...
