Homework Problem about the Work-Energy Theorem
In summary: :) in summary, the work-energy theorem states that the work done on an object is equal to the product of its mass and the energy transferred to it. in this case, the mass is the puck and the energy transferred is the force of friction. this equation can be used to find the force of friction between two objects.
aquamarine08
23
[SOLVED] Homework Problem about the Work-Energy Theorem
Please help! This is my first year of taking physics and I am really confused...
A puck on a shuffleboard decreases in speed from 1.0 m/s to .20 m/s while traveling 4.0 m. What is the coeffecient of kinetic friction between the puck and the board?
I think that the equations we have to use to solve this would be...
w= [tex]\frac{1}{2}[/tex]m[tex]V_{1}^{2}[/tex]-[tex]\frac{1}{2}[/tex]m[tex]V_{o}^{2}[/tex]
w=Fd
[tex]F_{f}[/tex]=[tex]\mu[/tex][tex]F_{N}[/tex]
w = [tex]\frac{1}{2}[/tex]k[tex]d^{2}[/tex]
k= [tex]\frac{1}{2}[/tex]m[tex]V^{2}[/tex]
First : I was thinking about using the equation w= [tex]\frac{1}{2}[/tex]m[tex]V_{1}^{2}[/tex]-[tex]\frac{1}{2}[/tex]m[tex]V_{o}^{2}[/tex] to solve for work, then substitute the work value in for w=Fd then somehow put it in the equation [tex]F_{f}[/tex]=[tex]\mu[/tex][tex]F_{N}[/tex] . Then I got extremely confused...and I realized that I don't have the mass of the puck to put into the first equation.
Second try: So, I decided to use w = [tex]\frac{1}{2}[/tex]k[tex]d^{2}[/tex] but in order to find out the k (spring constant) value, I need to use the equation k= [tex]\frac{1}{2}[/tex]m[tex]V^{2}[/tex]...which again, I don't have the mass for.
Third try...I was going to use the equation F=kd to figure out F and then substitute it in for w in w=Fd and then solve for m in w= [tex]\frac{1}{2}[/tex]m[tex]V_{1}^{2}[/tex]-[tex]\frac{1}{2}[/tex]m[tex]V_{o}^{2}[/tex]
. But I don't have the k again!
And now, I'm out of ideas...please help me...thank you! :) I hope this question makes sense...and my tries...if not, let me know and I'll try to fix them up! Thanks again!
Find the retardation of the body by using kinematic equatuon. Retarding force = m*a and normal reaction = mg. Plug it in the equation to get coefficient kinetic friction
Try this
Force of friction is given by:
[tex]F_{f}[/tex] = [tex]\mu[/tex] N [1]
Solving for [tex]\mu[/tex] we have
[tex]\mu[/tex] = [tex]\frac{F_{f}}{N}[/tex] [2]
The normal force N is given by:
N = mg [3]
Substituting [3] into [2] we have:
[tex]\mu[/tex] = [tex]\frac{F_{f}}{mg}[/tex] [4]
The force of friction is also defined by:
[tex]F_{f}[/tex] = ma [5]
where a is the deceleration and m is the mass of the puck. We also know given a distance and a constant acceleration (or deceleration in this case) that the acceleration is equal to the following (see: http://library.thinkquest.org/10796/ch3/ch3.htm ):
a = [tex]\frac{(V_{f}^{2} - V_{i}^{2})}{2d}[/tex] [6]
Substituting [6] into [5] we have:
[tex]F_{f}[/tex] = [tex]\frac{m(V_{f}^{2} - V_{i}^{2})}{2d}[/tex] [7]
and finally substituting [7] into [4] we have:
[tex]\mu[/tex] = [tex]\frac{(V_{f}^{2} - V_{i}^{2})}{2dg}[/tex]
photonsquared, I used your method to solve the problem...it made sense to me and this is the answer that I got [tex]\mu_{k}[/tex]= .0122. Is there anyway you could tell me if this is correct? Thank you very much for your help! :smile:
That is the same value I calculate. The reason you don't need the mass of the puck is because the masses cancel out when you substitute eqn 7 into 4. Hope this helps.
Ok thank you very much photonsquared! :) Thanks rl.bhat for your response!
FAQ: Homework Problem about the Work-Energy Theorem
What is the Work-Energy Theorem?
The Work-Energy Theorem is a fundamental concept in physics that states that the net work done on an object is equal to the change in its kinetic energy. In other words, work and energy are directly related and can be used to understand the motion of objects.
How is the Work-Energy Theorem used?
The Work-Energy Theorem can be used to solve a variety of problems involving the motion of objects. It allows us to calculate the work done on an object by a force and determine the resulting change in its kinetic energy. This can be useful in understanding the speed and direction of an object's motion.
What types of problems can be solved using the Work-Energy Theorem?
The Work-Energy Theorem can be applied to a wide range of problems, including those involving objects moving on inclined planes, pendulums, and collisions. It is also commonly used in problems involving conservation of energy.
How does the Work-Energy Theorem relate to other physical principles?
The Work-Energy Theorem is closely related to the concepts of work, energy, and power. It is also related to the laws of conservation of energy and momentum. By understanding how these principles work together, we can better analyze and solve problems involving the motion of objects.
What are some real-life applications of the Work-Energy Theorem?
The Work-Energy Theorem has many practical applications, such as understanding the energy efficiency of machines and calculating the speed of objects in motion. It is also used in fields such as engineering, sports, and transportation to design and optimize systems for maximum efficiency and performance.
