Homework Problem Regarding Linearization
In summary, the student is having trouble with a homework assignment and is looking for help. The problem is: find the slope, write down what the slope means/represents, then find k. They attempted to solve for the slope with a scatterplot and found that m is 10. However, whenever they try to equate 10 and h, they are not equal.
student23561235
Hey Guys, I don't really want to have to post this in of all places due to how advanced everyone else is compared to me, but I went to my second physics class and I have a huge problem. My teacher gave me my homework, but I have no idea on Earth how to do it because she rushed the lesson because of a pep rally. I'm sure I'm not the only one in my class with this same problem, but I'd rather not give up on my first day of physics class.
The problem is: mgh = 1/2kx^2
and she simply asks: Find the slope, Write down what the slope means/represents, then find k.
g is gravity (9.8 m/s^2)
k is spring constant (what she wants us to solve for)
m is mass of marble (.2 kg)
h is maximum height achieved
x is distance the spring has been compressed.
It also comes with a table,
Distance Spring is Compressed (m) | Max Height Achieved (m)
.05 | .219
.1 | .875
.2 | 3.5
.3 | 7.88
.4 | 14
.5 | 21.9 but there's a catch. You have to graph it in excel and linearize the data to be allowed to find the slope,
instead of simply solving for it algebraically (at least I think she didn't want us to do that.)
simple as that. At least I think this is simple. This was my first day of physics after all.
My attempt was creating a scatterplot of x(distance compressed) vs. h(max height) to the square root in order to try to linearize it. When done, it does create a linear graph with a solvable slope of 10.
However, whenever you place 10 into the spring constant and check to see if they are equal by inputting a corresponding x and h, they aren't equal. Where am I messing up here? I know the answer will probably be painfully obvious to you, and honestly, I don't mind if you come off rude. I'm here to learn, any replies would be amazing.
If I have time later, I will try to take a look at it, but there are a lot of smart guys on here. Someone will probably help you out before I get back to you.
This is just meant as a little encouragement: When I was taking my first semester physics (long ago and far away), I went into my professor, frustrated, and said something like, "I just don't know how to do these problems." This is what he said to me: "You are probably used to being able to look at a problem and know immediately how to solve it. In physics, it won't always be that way. You just have to start working with what you have." That was very comforting to me. I stuck it out and got through it. Hang in there. And don't feel bad about not knowing as much as the people here. In that regard, here's a twist on a cute little story I heard.
A man came into a town he had never been to before and saw an old man sitting in front of the drug store. So he walked up to the old man and said, "Were any famous physicists born here?" The old man responded, "No, only babies."
Hello, and welcome to PF!
When plotting a linear relation Y = mX + b between two variables (Y vs. X), note that the slope, m, is the coefficient of X (the variable plotted on the horizontal axis).
If you plot x vs h1/2, what is the coefficient of h1/2 in the linear relation between x and h1/2?
Instead of plotting x vs h1/2, you might consider a different plot with h plotted on the vertical axis. Then what would you plot on the horizontal axis to get a linear relation? How would the spring constant be related to the slope of this graph?
:smile:
Likes TomHart
Related to Homework Problem Regarding Linearization
What is linearization and why is it important?
Linearization is the process of approximating a nonlinear function with a linear function. It is important because it allows us to use simpler mathematical tools and techniques to solve complex problems. It also helps us understand the behavior of a nonlinear function in a specific region around a point.
How is linearization used in real-life applications?
Linearization is used in many real-life applications, such as in physics, engineering, economics, and biology. For example, it is used to model the behavior of electronic circuits, to analyze the stability of control systems, and to predict the growth of populations in biology.
What are the steps for linearizing a function?
The steps for linearizing a function are:
  1. Identify the point around which you want to linearize the function.
  2. Calculate the first derivative of the function at that point.
  3. Substitute the point and the derivative into the formula for the tangent line.
  4. Simplify the resulting equation to obtain the linearized function.
What are the limitations of linearization?
Linearization is only accurate within a specific region around the point of linearization. If the function has a steep curvature or changes rapidly, the linearization may not accurately represent its behavior. Additionally, the linearization may not hold for values outside of the region of linearization.
How can linearization be used to solve homework problems?
Linearization can be used to simplify complex functions and make them easier to solve. It can also help in understanding the behavior of a function and making predictions about its values. Additionally, linearization can be used to approximate the solutions to a problem, which can be helpful in checking the accuracy of a solution obtained through other methods.
