Homogeneity and isotropy in Big Bang model
In summary: The point of the Big Bang model, as explained by Chalnoth, is that the universe started out incredibly small and dense, and has since been expanding. This expansion is currently speeding up, and according to the cosmological principle, the universe should be uniformly filled with matter and radiation. However, there are some apparent problems with this principle: first, there is no clear center for the universe, and second, even if there was, the isotropy principle would only be valid within a certain radius from this center.
Goddar
205
Hi there.
I'm having a hard time understanding the precise meaning of the so called "cosmological principle":
My understanding of the general Big-Bang model is that far enough back in time the observable universe came down to something very small (compared to now), very dense, very hot... Ok, i would have other questions about that but it's not the topic here.
So, the next picture is one of this "small" universe spreading incredibly, part of which probably due to inflation (but maybe not?), the other part comparable to the way a gas concentrated in a small region would rapidly spread due to random motion of its particles.
Now in this picture i don't see how to justify the assumption of homogeneity throughout all space: it seems that there is a natural, effective center of momentum in the universe and we can expect homogeneity at a given radius from this center (in terms of matter density and therefore metric as well), and also isotropy with respect to this center, but certainly not for any arbitrary point in the observable universe... Also, say we're standing at the edge of this universe: there's certainly no sense of homogeneity and isotropy so what is wrong with my understanding, please?
This might be very basic but i doubt I'm the only beginner in Cosmology who doesn't understand it...
Thanks!
Space news on Phys.org
It seems that you are visualizing the universe as a lump of gas that started expanding. This is false. There is no reason to believe that there is any edge to the universe, and certainly if there is anything like an edge it's far beyond our horizon such that it has no impact. Either way, it is valid to conceptually think of the universe as being infinite in every direction. Early-on, it wasn't small, it's just that things were closer together.
And to add to what Chalnoth said, you seem to be envisioning a center, but there was no center. The initial event happened throughout the entire universe, whatever size it was (infinite or otherwise) not at some single point. I realize you probably already know this, but just to be clear, "singularity" does not mean "point" it just means "the place where, if you extrapolate backwards in time, the math model breaks down and we don't know what was really going on".
Thanks for the reply.
Ok. Then what's the right picture (in Big Bang model, i mean)?
I meant an "edge" in the sense that a Big Bang model seems to suppose a finite amount of matter (maybe locally? there could be many local Big Bangs..), and this matter would be spread within a finite volume of space (regardless of how space would even be defined outside of it), which volume would then necessarily have an "edge"?..
Well the universe may or may not be infinite and we'll probably never have the answer to that, but that's not really the question here, i think... I understand the universe was "closer together", that's what i really meant by saying "compared to now", but that doesn't seem to undermine the picture of an expanding ball...
Thanks, Phinds.
I understand your point; it seems though that we can still determine an effective "center" (i.e. the center-of-momentum) at any time? That would seem to make the isotropy principle only valid with respect to this point (and i don't mean in some absolute space, but in a purely relational sense..)?
Goddar said:
Thanks, Phinds.
No, there is no center of momentum. Everything is moving away from everything else. No edge, no center. Hard to get your head around at first, I know. It seems sort of "human nature" to believe there has to be a center and an edge, but it just doesn't work that way.
Even if the universe is not infinite, it is almost certainly unbounded, so still no edge and no center.
The universe didn't expand into anything, it just expanded. Weird, but true to the best of our understanding.
Yep, indeed it's starting to sound like black magic...
I'm not going to insist because i hate to be annoying but indulge me one last bit, please.
So to be clear we're talking about a universe that doesn't necessarily require extra-dimensions and where the metric is nearly flat;
Let's imagine this universe, whatever process has made it happen, has produced only a handful of galaxies (say, 3), which are moving away from each other at non-relativistic but slowly accelerating speeds;
Passengers on these galaxies (i.e. at rest with respect to their respectful galaxies), once they figured their relative velocities and accelerations, can always agree on a unique center of momentum, which is the center of mass at any time and is independent of the coordinates' system. Right?
Then the "edge" of this universe is, entirely subjectively but straight-forwardly, understood as the triangle formed by these three objects at any time.
Now just add a few billion galaxies and the same concepts can still be applied, so what goes wrong here and what's the alternative picture i can't seem to grasp?
You seem to imagine that expansion means that galaxies are moving away from each other. This is not the idea but a very common misconception. It is not galaxies which are moving but space itself that is expanding. There is a cosmologically preferred frame (the CMB frame), but that is only ever going to give you a preferred velocity, not a point in space. Regardless of where you are, if you are a comoving observer (ie, at rest relative to the CMB) the Universe will look the same wherever you are.
Likes Goddar
timmdeeg said:
@: Goddar, have you seen this?
http://www.phinds.com/balloonanalogy/
Yeah, I should have pointed that out myself. I forget about it sometimes. On the other hand, I don't really say anything much in it that I haven't said in this thread, just more of it.
Thank you, Orodruin. (and others, sorry i hadn't seen yet!)
Yes, i always understood that this is what was observed (i mean on average: i know they can also cross paths, collide or even orbit each other at times..);
My understanding (so far) was also that the interpretation of space itself expanding is suggested by the accelerating rate but "moving away" is still what we observe?
Now if we observe that the universe looks exactly the same in every direction and there is no sense of a historical Big-Bang "zone" (with respect to every observable thing) and space itself expands then it sounds like the universe lives on a 3-sphere (the surface of a 4-ball), hence the usual analogy of a 2-sphere...
Now this is a closed surface so it would also mean that by going any direction for a long time, a traveler or light ray would come back to its sender?.. Would also suggest embedding in a 4th dimension...
Don't worry, you can always rely on me.:smile:
Regardless his position in the universe, an arbitrary observer will see the galaxies moving away. In terms of "true physics" one can only say that the distances between commoving objects are increasing. The notion of expanding space itself like a substance analogously to the rubber in said analogy is just a picture, not wrong, but not true physics.
You are right, the balloon analogy stands for a spherical universe, which would be finite. According to the data it is spatially flat however. Regarding this aspect it's better to think of an expanding rubber sheet (which is infinite) therefore.
Likes Goddar
With accelerated expansion the light signal sent from sufficiently far away will never reach an observer, so even in a closed universe you don't get to see the back of your head - you are confined to a limited region of observable universe.
Space being closed also doesn't necessarily imply embedding in higher-dimensional space. One can have a perfectly defined curved, closed space without the need for any higher dimensions. For example, in the balloon analogy, the third dimension is unnecessary to describe how the geometry of the surface behaves. It's easier to visualise by placing it in 3D, but not necessary.
Likes Goddar and marcus
Thanks for the input, guys.
Ok. The other, more obvious interpretation would be that we happen to sit on a more or less central region of an expanding-ball like universe but i understand this is discarded on the grounds that we have no reason to feel special... still possible though, since homogeneity and isotropy are still assumptions?..
Not really getting that: in the 2D analog the signal does eventually hit the back of your head unless the universe foils on itself like an "infinite" onion or expansion has reached light-speed radially. In 3D the same logic should follow, it seems..
Point taken. Thought about it after posting, actually.. Still a sensible temptation, maybe?
One thing you might not be aware of is this: "the universe" is generally taken to either infinite or to be many orders of magnitude greater than the observable universe and things at the edge of the observable universe are now receding from us at about 3c and everything farther away than that is receding even faster, so the "wrap-around" topology still absolutely does not mean that you could ever see the back of your head.
Likes Goddar
Right, i get that. With large enough "universe", expansion will work to make a signal never reach back..
Probably time to wrap-up this post and dig more into the literature.
Thanks, guys!
FAQ: Homogeneity and isotropy in Big Bang model
What is the meaning of homogeneity and isotropy in the Big Bang model?
Homogeneity refers to the idea that the universe looks the same at every point in space, meaning that there are no preferred locations in the universe. Isotropy refers to the idea that the universe looks the same in all directions, meaning that there are no preferred directions in the universe. In the Big Bang model, these concepts are important because they help explain the large-scale structure of the universe.
How does the Big Bang model incorporate homogeneity and isotropy?
The Big Bang model assumes that the universe started from a single point and has been expanding and cooling ever since. This initial singularity was homogenous and isotropic, meaning that it was the same at every point in space and in all directions. As the universe expanded, this homogeneity and isotropy continued on a larger scale, leading to the large-scale structure we see today.
What evidence supports the homogeneity and isotropy of the universe in the Big Bang model?
Several pieces of evidence support the homogeneity and isotropy of the universe in the Big Bang model. The first is the cosmic microwave background radiation, which is a remnant of the hot, dense early universe. This radiation is highly uniform in all directions, supporting the idea that the universe is isotropic. Other evidence includes the large-scale distribution of galaxies and the observed isotropy of the cosmic microwave background radiation.
Are there any exceptions to the homogeneity and isotropy of the universe in the Big Bang model?
While the universe is generally considered to be homogenous and isotropic on large scales, there are some small-scale variations in the distribution of matter and energy. These variations are thought to be the seeds of the structures we see today, such as galaxies and clusters of galaxies. Additionally, the presence of large-scale structures, such as galaxy clusters and superclusters, may suggest that the universe is not completely homogenous on a large scale.
How does the concept of homogeneity and isotropy in the Big Bang model relate to the expansion of the universe?
The concept of homogeneity and isotropy is closely related to the expansion of the universe in the Big Bang model. The uniformity of the universe on large scales suggests that the expansion is happening at a constant rate in all directions. Additionally, the expansion of the universe is thought to have started from a single point, which was homogenous and isotropic, and has continued to be homogenous and isotropic as the universe has expanded. This supports the idea that the expansion is happening equally in all directions, leading to the homogeneity and isotropy we observe today.
