MHB Homomorphic Images of Free Modules .... Bland, Proposition 2.2.6 .... ....
  • Thread starter Thread starter Math Amateur
    Images Modules
The discussion centers on understanding Proposition 2.2.6 from Paul E. Bland's "Rings and Their Modules," specifically regarding the proof's details. The key points involve clarifying how an element \( x \in M \) can be expressed as a sum involving generators \( x_\alpha \) and why this implies that \( (a_\alpha) \in R_{(\Delta)} \). Additionally, the definition of the function \( f \) and its calculation is discussed, confirming that \( f \) is indeed an epimorphism as it maps elements from \( R^{(\Delta)} \) to \( M \) effectively. The explanation concludes that the proof's structure validates the properties of \( f \) as an epimorphism, addressing the initial questions raised. Understanding these concepts is crucial for grasping the implications of free modules in the context of homomorphic images.
Math Amateur
MHB
I am reading Paul E. Bland's book: Rings and Their Modules and am currently focused on Section 2.2 Free Modules ... ...
I need help with some aspects of the proof of Proposition 2.2.6 ...
Proposition 2.2.6 and its proof read as follows:
Near the end of Bland's proof we read the following:
" ... ... If $$x \in M$$, then $$x$$ can be written as $$x = \sum_{ \Delta } x_\alpha a_\alpha$$, where $$a_\alpha = 0$$ for almost all $$\alpha \in \Delta$$. It follows that $$( a_\alpha ) \in R_{ ( \Delta ) }$$, so $$f (( a_\alpha )) = \sum_{ \Delta } x_\alpha a_\alpha$$ and $$f$$ is an epimorphism. ... ... "My questions are as follows:Question 1
Why/how exactly does it follow from $$x \in M$$ and $$x = \sum_{ \Delta } x_\alpha a_\alpha$$ that $$( a_\alpha ) \in R_{ ( \Delta ) }$$ ... ?
Question 2
In the above quote Bland writes $$f (( a_\alpha )) = \sum_{ \Delta } x_\alpha a_\alpha$$ ... but what is going on ... ? At the start of the proof he defined $$f$$ this way ... but if he is not relying on this definition how does he calculate/formulate $$f$$ ...Question 3
Why/how exactly is $$f$$ an epimorphism ...Help will be appreciated ...
Peter
Read the proof this way:
$M$ is generated by $\{x_\alpha\}_\Delta$ (every module has a set of generators).
Define $f:R^{(\Delta)} = \bigoplus_\Delta R_\alpha \longrightarrow M$ (where $R_\alpha = R$) by
$f((a_\alpha)_\Delta) = \Sigma_\Delta x_\alpha a_\alpha $ for $(a_\alpha)_\Delta \in R^{(\Delta)}$ ($a_\alpha = 0$ for allmost all $\alpha \in \Delta$).
$f$ is $R$-linear (follow the proof in the book)
Now prove that $f$ is an epimorpism:
Take $x \in M$ then $x = \Sigma_\Delta x_\alpha, r_\alpha$ where $r_\alpha \in R$ (and $r_\alpha = 0$ for allmost all $\alpha \in \Delta$).
Obviously $(r_\alpha)_\Delta \in R^{(\Delta)} = \bigoplus_\Delta R_\alpha$ and it follows that
$f((r_\alpha)_\Delta) = \Sigma_\Delta x_\alpha r_\alpha = x$.
Therefore $f$ is an epimorpism.
That answers Q2 and Q3, you can anser Q1 yourself.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
