Hooke's experiment and spring launcher
In summary, Hooke's law states that the force exerted by a spring is directly proportional to its extension, given by F = kx, where x is the extension and k is the spring constant. To calculate the elastic potential energy stored in the spring, you can use the formula 0.5kx^2. This energy is then converted into kinetic energy when the spring is released, and the velocity of the ball can be calculated using the formula v = sqrt(kx/m). Additionally, when the angle of the launcher increases, the distance traveled by the spring also increases. However, this may seem counterintuitive due to the higher angle creating more height in the projectile motion.
starrish
Hooke's Law Experiment: what is force and extension table of values?, finding the spring constant and calculating one initial launch velocity of my spring launcher?
Fx=k(x)
researching on google...need someone to clear up the concept
Ok, basically hooke's law states that within an elastic limit of a material, the Force is directly proportional to its extension, given by F = kx, where x is the extension in metres, and k is the spring constant with units [N/m].
Say, a spring has a spring constant of 360N/m, so for every 1m u compress the spring, the spring exerts a force in opposite direction of 360N.
Looking at the thumbnail attached, u can see that its a force-extension graph illustrating hooke's law, with gradient of k [360N/m]. To calculate the ELASTIC POTENTIAL ENERGY stored in the spring, its Force x distance, which is the area under the graph, shaded in blue.
Therefore, Elastic Energy = 0.5Fx = 0.5(kx)x = 0.5kx2.
Assuming a spring is compressed by x metres, it contains elastic potential energy of 0.5kx2. Then following the law of conservation of energy, where all elastic potential energy is converted into kinetic energy of the ball being launched.
0.5kx2 = 0.5mv2
kx = mv2
v = sqrt(kx/m)
Hope this clarifies your doubt.
force-extension diagram
This is the force extension diagram as described in my previous post.
thank you that helped a lot...and ur username is very ironic. But other than that there's a new problem for me now, how do i make an energy and distance/range graph. And also i have noticed that as the angle value for my launcher goes higher, the distance my spring travels increases. But since the higher angle created more height in the projectile motion created by my spring wouldn't my results be vise versa, and the higher the angle is...the lower the distance?
FAQ: Hooke's experiment and spring launcher
What is Hooke's Experiment?
Hooke's experiment is an experiment conducted by Robert Hooke in the 17th century to demonstrate the relationship between the force applied to a spring and the resulting displacement.
What is a spring launcher?
A spring launcher is a device used to launch objects by utilizing the potential energy stored in a compressed spring. It typically consists of a spring attached to a platform or lever, which is released to launch the object.
How does Hooke's Experiment work?
In Hooke's experiment, a spring is attached to a fixed surface at one end and a weight is attached to the other end. By adding weights to the spring, Hooke observed that the spring stretched proportionally to the weight added, demonstrating Hooke's Law which states that the force applied to a spring is directly proportional to its displacement.
What are the applications of Hooke's Experiment and spring launcher?
Hooke's Experiment and spring launcher have various applications in fields such as physics, engineering, and medicine. They are used to study and understand the properties of springs, as well as in the design of various devices such as shock absorbers, suspension systems, and prosthetics.
What are the limitations of Hooke's Experiment and spring launcher?
One limitation of Hooke's Experiment and spring launcher is that they assume that the spring is perfectly elastic, which may not be the case in real-world situations. Additionally, the experiment does not take into account factors such as friction, air resistance, and the weight of the spring itself, which may affect the results.
