Hooke's law and circular motion.
In summary, the conversation discusses a zero gravity experiment involving a spring attached to 1.0 kg masses rotating at 1.0 revolution per second with a radius of 70 cm. The question is how much the spring is stretched and what force it exerts. The formula for centripetal force is equated to Hooke's Law, but the posted equation does not seem to match. By comparing the radius of each mass's revolution to the unstretched length of the spring, it can be determined how much the spring is stretched. The distance between the masses can also be found, and a physical interpretation of the situation is discussed.
  • #36
The force acts in a point. If you speak about an extended body, with forces acting at different points, you can sum up the individual equations miai=Fi, and arrive at the equation for the acceleration of the centre of mass: aCM∑mi=∑Fi . If there are only forces of interaction (no external force) the sum of forces is zero. The system, which has 2 kg mass altogether, has zero acceleration. But the individual masses feel the force of the spring and have centripetal acceleration.
ehild
  • #37
negation said:
It hit me that since we considered the total change in length of the spring due to the 2 masses, we give consideration to the total mass.
A stretched spring has tension. To keep it stretched there must be forces equal to that tension acting at both ends. You can not exert force on a spring if the other end is free. Hook's law refers to the tension which is equal to kΔL, and it is equal to the force acting on one end of the spring (but force of the same magnitude and opposite direction has to act on the other end).
Again, the net force on the stretched spring is zero, as the forces acting at the ends are opposite and of equal magnitude.
ehild
