Hooke's Law and Simple Harmonic Motion
In summary, the period increases as the mass increases. This is shown by the second derivative of x which is -A^2 cos(omega t+phi).
Soaring Crane
469
We did an experiment with a vertical spring-mass system. Here is an example of data collected:
Mass------------T (period)
200 g-----------.3 s
400g------------.5 s
My question is why does the period increase as the mass increases?
I know that the amp. and T are independent of each other, but how do you show this mathematically? I now it’s easy to show visually, but are there any ties in deriving this, along with the relationship that T = 1/sqrt(x)?
Then, my teacher mentioned some of the following derivisions. I understand a majority of it, but I don’t know how these two parts directly correspond with each other. Does this look familiar to anyone? I don’t quite follow the M_efficiency line, but I do get the calculus.
1st Part
F = -kx, where T = 2*pi*sqrt(M/k) and Mg = kL (L=x)
M*[(d^2*x)/(dt^2)] = -(k/M)x (second derivative)
(d^2*x)/(dt^2) = -w^2*x, where w (or omega) = 2*pi*f
x(t) = Asin(wt + phi)
This is to show that T is proportional to k, I guess.
2nd Part
M_efficiency = M + (M_spring/3)
k_spring = (1/2) integrate(dx/dt)^2 dm
Proportion
v/L = (dx/dt)/x
mass density p = dm/dx, where p = M_spring/L, where L is length
k_spring = (1/2)*definite integral(xv/L)^2 pdx L to 0
k_spring = ½*[(pL^3v^2)/(3L^2)] = ½*(M_spring/3)v^2
and somehow KE = ½[M + (M_spring/3)]*v^2. How do you get to this point?
Thanks for ANY help.
I don't know about M efficiency or whatever.
But the period proportional to the mass is pretty simple to explain.
[tex]
F = m\ddot{x} = -kx
[/tex]
[tex]
\ddot{x} + \frac{k}{m}x = 0\ \ \ \ (1)
[/tex]
now you know that x itself is a function and can be modeled as:
[tex]
x = A \cos ( \omega t + \phi )
[/tex]
taking the first derivative gives you:
[tex]
\dot{x} = -A\omega \cos ( \omega t + \phi )
[/tex]
the second derivative gives you:
[tex]
\ddot{x} = -A\omega ^2 cos ( \omega t + \phi )
[/tex]
notice that's also equal to:
[tex]
\ddot{x} = - \omega ^2 x
[/tex]
substituting this in equation (1) gives you:
[tex]
-\omega ^2x + \frac{k}{m}x = 0
[/tex]
Solving for omega gives you
[tex]
\omega = \sqrt{\frac{k}{m}}
[/tex]
so the period will equal to:
[tex]
T = 2\pi \sqrt{\frac{m}{k}}
[/tex]
[tex]
[/tex]
Should be [tex]\dot{x} = -A\omega \sin (\omega t + \phi)[/tex].
Could you explain the first line before Equation 1? How did you get from that line to Equ(1)?
Thanks.
He got that line by simply applying Newton's 2nd Law (For Constant Mass).
[tex] \sum_{i=1}^{n} \vec{F}_{i} = m \vec{a} [/tex]
Is there a relationship between displacement and period? How do I go about showing this mathematically?
Thanks.
FAQ: Hooke's Law and Simple Harmonic Motion
1. What is Hooke's Law and how does it relate to Simple Harmonic Motion?
Hooke's Law states that the force required to stretch or compress a spring is directly proportional to the displacement of the spring from its equilibrium position. This directly relates to Simple Harmonic Motion because it describes the motion of an object that follows a sinusoidal pattern and is caused by a restoring force that is proportional to the displacement from equilibrium.
2. What is the formula for Hooke's Law?
The formula for Hooke's Law is F = -kx, where F is the force applied to the spring, k is the spring constant, and x is the displacement from equilibrium position. This formula shows the direct relationship between the force and displacement in a spring.
3. What is the significance of the spring constant in Hooke's Law?
The spring constant, represented by the letter k, is a measure of the stiffness of a spring. It determines how much force is required to stretch or compress a spring by a certain amount. A higher spring constant means the spring is stiffer and will require more force to stretch or compress, while a lower spring constant means the spring is less stiff and will require less force.
4. How is Hooke's Law applied in real-life situations?
Hooke's Law can be applied in various real-life situations, such as in the design of springs for suspension systems, measuring weight using a spring scale, and in medical devices like prosthetics and braces. It is also used in various scientific experiments to study the behavior of springs and other elastic materials.
5. Can Hooke's Law be applied to other systems besides springs?
Yes, Hooke's Law can be applied to other systems besides springs, as long as they exhibit the characteristics of Simple Harmonic Motion. These systems include pendulums, guitar strings, and even molecular bonds. As long as there is a restoring force that is directly proportional to the displacement from equilibrium, Hooke's Law can be used to describe the motion of the system.
