Hooke's Law/Poisson's Ratio and a bar
  • Thread starter Thread starter Autanimous
    Ratio
A round bar of aluminum alloy 7075-T6 with a 10 mm diameter experiences a diameter decrease of 0.016 mm when stretched by axial forces. The modulus of elasticity is given as 72 GPa, and Poisson's ratio is 0.33. The initial calculations for the load P resulted in an incorrect value of 361.911 kN, while the correct answer is 27.4 kN. The discrepancy was attributed to a misunderstanding of the equations and the application of Poisson's ratio. After reviewing the material, the correct approach was identified, resolving the confusion.
Autanimous
A round bar of 10 mm diameter is made of
aluminum alloy 7075-T6 (see figure). When the bar is
stretched by axial forces P, its diameter decreases by
0.016 mm.
Find the magnitude of the load P. (Obtain the material
properties from Appendix H.)
From Appendix H:
Modulus of Elasticity (E) = 72 Gpa (Kn/mm^2)
Poisson's Ratio (v) = .33
ε = axial strain
ε' = lateral strain
σ = axial stress
L = Length of bar
δ = change in length
A = Area
σ = E*ε
ε = δ/L
σ = P/A
v = ε' / ε
A = pi*(10 mm )^2 = 314.159 mm^2
ε = (.016mm) ----------------that's right isn't it?
P = σ*A = ε*E*A = (.016mm)*(314.159 mm^2) * (72 Kn/mm^2)
= 361.911 Kn
However, the book says the answer is 27.4 Kn
I'm lost and sad ;-; Where am I going horribly horribly wrong? I figure it's the fact I'm not using the Poisson's ratio (as this section of homework was titled Hooke's Law and Poisson's ratio after a chapter in my book), however it didn't seem to come into play. This could stem from a mis-reading of one of my equations... however I've looked at them multiple times, so either my book is just confusing me or something else is wrong. Thank you for your help *bows*
Is this a more 'upper level' problem that should've been in the other section? I should get a chance to ask my teacher about it later today, though he won't be able to give me much time on the subject the way the schedules work out.
"its diameter decreases by
0.016 mm." is epsilon dash.
Now you can work out epsilon.
Yes, thanks. I'm sorry I never responded here but I did an overhaul reading of the material and I got it right. I for some reason continued to have a small power of ten problem, but otherwise the numbers matched up with what was expected.
It is for the very reason you described.
14K
10K
