Horizontal component of the Coriolis force
The Coriolis force acting on an object moving on Earth is defined by the equation Fcor = 2m(v × ω), where m is the object's mass, v is its velocity, and ω is Earth's angular velocity. The discussion questions whether the horizontal component of this force can be expressed as 2mωv sin θ, with θ being the angle between ω and v. It is clarified that this formula represents the magnitude of the Coriolis force, not specifically its horizontal component. Acknowledgment of the misunderstanding leads to a suggestion to review the relevant chapter for better comprehension. Understanding the distinction between the total force and its components is crucial for accurate application of the Coriolis effect.
MatinSAR
Show that the horizontal component of the Coriolis force is independent of the direction of motion of the particle on Earth's surface.(The particle is moving on a horizontal plane.)
Newton's Laws in non-inertial reference frames.
The coriolis force that acts on the object moving on the Earth is: $$F_{cor}=2m(\vec v \times \vec \omega)$$##F_{cor}## is the Coriolis force, ##m## is the mass of the object, ## \vec{v}## is the velocity of the object in the Earth frame, and ## \vec{\omega}## is the angular velocity of the Earth.
Is it true to say that the horizontal component of this force is equal to ##2m \omega v \sin \theta## where ##\theta## is the angle between ##\vec \omega## and ##\vec v##?
That is the formula for the magnitude of the Coriolis force. Not for its horizontal component.
Thank you for pointing out my mistake. I think I need to reread this chapter before trying to solve.
