Horizontal force on a pendelum - what drives it upwards?
In summary, the conversation discussed the behavior of a pendulum supported by a wire under the influence of a horizontal force. It was determined that gravity and the normal force play a role in the pendulum's motion and that its speed will change due to conservation of energy. The conversation also touched upon the forces acting on the pendulum and the possibility of drawing vectors to represent them.
Nikitin
735
27
Two questions:
1) If you have a horizontal force in the x direction on a pendelum supported by a wire, then it will go upwards and in the x-direction. What is the vertical component which drags it upwards?
Is it the normal force which adjusts itself along the wire to match the horizontal force?
2) During the act of motion, will the speed be constant if the force isn't too big? Ie, will the normal force adjust itself in such a manner that it matches the horizontal force and gravity in magnitude?
Nikitin said:
Two questions:
Yes, if I understand "normal force" to mean "force normal to the motion", this is just the tension force in the wire.
It should be obvious that this is NOT true. Since the bob of the pendulum is moving in a vertical circle, its height, and so potential energy, changes. By "conservation of energy", its kinetic energy, and so its speed, must change. (And, of course, it has to come to a stop in order to go back the opposite direction.)
Gravity acts downwards and the applied force only has an x component: what other force is acting on the pendulum bob? What direction does it act in - so what is its upwards component?
Initially the pendulum is at rest. What is the speed after 1 second? What about after 0.001 seconds?
To understand what happens you really need to look at the direction of the forces and the velocity of the pendulum bob. Can you draw vectors to represent the forces at any point in time?
I meant while the horizontal force is still active.
mranchovy: yeah, I'll do that later.
1) The vertical component that drives the pendulum upwards is a combination of the normal force and the tension force in the wire. The normal force, which is perpendicular to the wire, helps balance the weight of the pendulum and allows it to move in a circular motion. The tension force, which is parallel to the wire, provides the necessary force to keep the pendulum in motion.
2) The speed of the pendulum will not be constant if the horizontal force is not too big. The normal force will adjust itself to match the horizontal force and gravity, but the speed will vary depending on the strength of the horizontal force. If the force is too strong, the pendulum may move faster and eventually break away from its circular motion. It is important to carefully control the horizontal force to maintain a constant speed and prevent any damage to the pendulum.
Related to Horizontal force on a pendelum - what drives it upwards?
What is a horizontal force on a pendulum?
A horizontal force on a pendulum refers to any external force acting on the pendulum in a horizontal direction, perpendicular to the direction of its swing. This force can either push or pull the pendulum in a horizontal direction, causing it to change its direction of motion or speed.
What is the purpose of a horizontal force on a pendulum?
The purpose of a horizontal force on a pendulum is to change its direction of motion or speed. This can be used to manipulate the behavior of the pendulum, such as causing it to swing in a circular motion or to increase or decrease its amplitude.
What drives a pendulum upwards?
A pendulum is driven upwards by the force of gravity acting on it. As the pendulum swings back and forth, the force of gravity pulls it towards the center of the Earth, causing it to gain potential energy as it moves upwards.
Can a horizontal force on a pendulum cause it to swing indefinitely?
No, a horizontal force on a pendulum cannot cause it to swing indefinitely. The force of gravity will eventually slow down the pendulum and bring it to a stop. In order to maintain the motion of a pendulum, a continuous external force must be applied.
How does the length of a pendulum affect the horizontal force on it?
The length of a pendulum does not directly affect the horizontal force on it. However, the length of a pendulum does affect its period and frequency, which can impact the behavior of the pendulum when a horizontal force is applied.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
