Horizontal Force on a trapeze pivot
In summary, the tension required to resist horizontal forces on a swinging trapeze is proportional to the mass of the bob, the angle at which the bob is released, and the length of the string.
Nthaoe
-sorry if I got the prefix wrong.
I'm working on calculating the forces on a trapeze bar, specifically, what tension I would need on guy wires to resists the horizontal forces on a swinging trapeze. If I could get the horizontal force generated by the the trapeze/pendulum I can do the rest.
Looking on various websites, and trying to remember my physics, I got the following formulas:
Tension on a pendulum swing = m*g*cosθ + m*v^2/L
Looking for a formula for velocity at any angle from the vertical up to 90°, I find, through kinetic energy, (and on this board),
v = √[2*g*L*(cosθ)]
When I set this up and started playing with values, I got numbers that were close to experience for speed & our experience of heaviness at the lowest point. And by setting this up on excel, and calculating the tension every 5 degrees, it seems as if the maximum horizontal force is at 45 degrees, no big surprise.
What did surprise me was when I changed the rope length, and the tension didn't change. It makes sense mathematically, if I put the velocity expression into the Tension equation, the lengths cancel out.
I've never seen this expressed in that way, that the tension on the string is not dependant on the length of the string, just on the mass of the bob, and the angle you release it at. (assuming no change in gravity). Am I getting that right?
Thanks for any help, riggers & trapeze artists will be grateful.
Hello Nthaoe, :welcome:
This is a difficult situation for PF: we can't assume any responsibilities for this kind of work.
But your physics/mathematics is just fine: ##v^2## is proportional to ##L## and the required centripetal force is proportional to ##v^2/L##.
Thanks, people in the circus world have been guying trapeze bars for a century, this wouldn't be used to create a minimal tie down. I was just surprised when I first looked into it that I couldn't find anyone who'd done the math.
-just out of curiosity, it's fairly common to be taught that the period of a pendulum is not dependant on the weight of the bob, just on the length of the swing, but I've never seen it expressed that the tension on the string doesn't increase when you increase the length of the string, creating a higher maximum velocity for a given angle. For some reason I find that even less intuitive.
Thanks for the confirmation,
Related to Horizontal Force on a trapeze pivot
1. What is a horizontal force on a trapeze pivot?
A horizontal force on a trapeze pivot refers to the external force that is applied on the pivot point of a trapeze. It can be in the form of a push or a pull, and it acts in a horizontal direction.
2. How is the horizontal force on a trapeze pivot calculated?
The horizontal force on a trapeze pivot is calculated by using the formula F = m x a, where F is the force in Newtons, m is the mass of the object, and a is the acceleration.
3. What is the significance of the horizontal force on a trapeze pivot?
The horizontal force on a trapeze pivot is significant because it determines the direction and magnitude of the resulting motion. It also affects the stability and balance of the trapeze.
4. How does the horizontal force on a trapeze pivot affect the movement of the trapeze artist?
The horizontal force on a trapeze pivot affects the movement of the trapeze artist as it provides the necessary support and momentum for the artist to perform various aerial maneuvers. It also helps in maintaining the balance and control of the trapeze.
5. Can the horizontal force on a trapeze pivot be controlled by the trapeze artist?
Yes, the horizontal force on a trapeze pivot can be controlled by the trapeze artist through their movements and positioning on the trapeze. By shifting their weight and using their body's momentum, the artist can manipulate the horizontal force and perform different tricks and stunts.
  • Other Physics Topics
  • General Math
