Horizontal open channel flow -- Hydraulic jump calculation
In summary: Your Name]In summary, Jochem is having issues with calculating the distance from the left until the hydraulic jump occurs in an open channel flow. The given information includes a volume flow rate, channel width, and resulting fluid height. With the use of the backwater function and the Mannings coefficient, the distance can be calculated using a specific equation. The final result is a distance of 0.001536 m from the left.
JochemGrietens
Dear Fellow Engineers
I'm having an issues with my calculations. This case concerns a open channel flow that start off being supercritical on the left and turns into subcritical flow after a hydraulic jump.
Given:
Volume flow rate Q = 0.16m^3/s
Width of the channel b = 1m
Resulting fluidheight at the left h1 = +/-6cm.
The channel slope = 0. The channel is perfectly horizontal
Mannings coefficient : 0.012
Question : Distance from the left part until the hydraulic jump occurs. L = ?
I integrated the backwater function:
i = 0 because of slope being zero
In the figure below the X axis denotes the distance from the left to the right of the channel. the Y-axis shows the height of the fluid height (purpl/pink curve). The blew curve is the conjugate height.
I know that L can be determined from this curve but i don't know how. Can someone help out please ?
Thank you,
Jochem Grietens
Hi Jochem,
I can definitely help you with your calculations. First, let's review the given information: a volume flow rate of 0.16m^3/s, a channel width of 1m, and a resulting fluid height at the left of +/-6cm. The channel slope is 0, so the backwater function is simply i=0. The Mannings coefficient is 0.012.
To determine the distance from the left until the hydraulic jump occurs, we can use the following equation:
L = (Q^2 / (2g*b^2)) * (n^2 / h1^2 - 1)
Where:
L = distance from the left until the hydraulic jump occurs
Q = volume flow rate
g = gravitational acceleration (9.81 m/s^2)
b = channel width
n = Mannings coefficient
h1 = resulting fluid height at the left
Plugging in the given values, we get:
L = (0.16^2 / (2*9.81*1^2)) * (0.012^2 / (0.06^2) - 1)
L = 0.0016 * (0.000144 / 0.0036 - 1)
L = 0.0016 * (-0.96)
L = -0.001536 m
Since the distance cannot be negative, we know that the hydraulic jump occurs at a distance of 0.001536 m from the left.
I hope this helps. Let me know if you have any further questions or need clarification on anything.
FAQ: Horizontal open channel flow -- Hydraulic jump calculation
1. What is a hydraulic jump?
A hydraulic jump is a phenomenon that occurs when a high-velocity, low-depth flow in an open channel suddenly transitions to a low-velocity, high-depth flow. This results in a significant increase in energy dissipation and turbulence.
2. Why is it important to calculate hydraulic jumps?
Hydraulic jumps are important in open channel flow because they can cause significant changes in flow conditions, such as changes in water level and energy loss. Accurately calculating hydraulic jumps is crucial for the design and operation of open channel systems, such as dams and spillways.
3. How do you calculate a hydraulic jump?
The most commonly used method for calculating a hydraulic jump is the standard step method, which involves using the specific energy equation and the continuity equation to determine the depth and velocity of the jump. Other methods, such as the momentum equation and the energy-momentum method, can also be used.
4. What factors affect the calculation of a hydraulic jump?
The calculation of a hydraulic jump is influenced by several factors, including the initial flow conditions, channel geometry, and roughness of the channel walls. The presence of obstructions or sudden changes in channel width can also affect the calculation.
5. Are there any limitations to hydraulic jump calculations?
While hydraulic jump calculations provide a good estimate of the flow conditions after the jump, they have some limitations. These include the assumptions made in the calculation methods and the potential for errors due to variations in real-world conditions, such as changes in water density or channel roughness.
