Horizontal veolocity given vertical velocity and angle
In summary, a person on a stationary train observes raindrops falling vertically at 8.7 m/s relative to the ground. When the train moves at a constant velocity, the raindrops make an angle of 67° as they pass the window. To find the speed of the train, use trigonometric functions such as cos, sin, or tan. Using the Pythagorean Theorem is not necessary.
IAmSparticus
36
A person looking out the window of a stationary train notices that raindrops are falling vertically down at a speed of 8.7 m/s relative to the ground. When the train moves at a constant velocity, the raindrops make an angle of θ = 67° when they move past the window as the drawing shows. How fast is the train moving?
Vx = V0x +axt
3.4 and 22.3 m/s are both incorrect.
Couldn't figure out how to do it since clearly you don't just use the Pythagorean Theorem... walk me through it?
Hi IAmSparticus! :wink:
You'd only use Pythagoras if you wanted the length of the third side.
But you only want the angle … so use cos or sin or tan. :smile:
I would first start by analyzing the given information and identifying the relevant variables and equations that can be used to solve for the unknown variable, which in this case is the horizontal velocity of the train.
From the given information, we know that the raindrops are falling vertically at a speed of 8.7 m/s relative to the ground. This means that the vertical component of the raindrop's velocity is 8.7 m/s. We also know that when the train is moving, the raindrops make an angle of θ = 67° as they pass by the window.
To solve for the horizontal velocity, we can use the equation Vx = V0x +axt, where Vx is the horizontal velocity, V0x is the initial horizontal velocity (which is 0 since the train starts from rest), a is the acceleration (which is also 0 since the train is moving at a constant velocity), and t is the time.
We can use trigonometry to find the value of V0x. Since we know that the raindrops make an angle of θ = 67° with the horizontal, we can use the trigonometric function cosine to find the value of V0x. The equation for this would be V0x = V0cosθ, where V0 is the initial velocity (in this case, the vertical velocity of the raindrops).
Substituting the known values, we get V0x = 8.7 m/s * cos(67°) = 3.4 m/s.
Now, we can plug this value into the original equation Vx = V0x +axt to solve for the horizontal velocity. Since a = 0, the equation simplifies to Vx = V0x, which is equal to 3.4 m/s.
Therefore, the train is moving at a speed of 3.4 m/s. This is the correct answer, as both 3.4 and 22.3 m/s were incorrect because they did not take into account the angle at which the raindrops were falling.
Related to Horizontal veolocity given vertical velocity and angle
1. What is horizontal velocity?
Horizontal velocity is the speed at which an object is moving in the horizontal direction, or side to side.
2. How is horizontal velocity related to vertical velocity and angle?
Horizontal velocity is directly affected by the angle at which an object is launched or thrown, as well as the vertical velocity. The higher the angle and vertical velocity, the greater the horizontal velocity will be.
3. Can horizontal velocity be negative?
Yes, horizontal velocity can be negative if an object is moving in the opposite direction of the positive horizontal axis. This can happen if an object is slowing down or changing direction.
4. How can horizontal velocity be calculated?
Horizontal velocity can be calculated using the formula v = v0 * cos(theta), where v0 is the initial velocity and theta is the angle at which the object is launched or thrown.
5. Is horizontal velocity affected by external forces?
Yes, horizontal velocity can be affected by external forces such as air resistance or friction. These forces can slow down or accelerate an object's horizontal velocity.
