- 28,975
- 4,279
But just before you rush to order one, watch this:
So it's a hoverboard in the same way as a draisine is a bicycle?Borek said:But just before you rush to order one, watch this:
Hoverboards use magnetic levitation technology to create a powerful magnetic field between the board and the ground. This allows the board to float and move without any physical contact with the ground.
Hoverboards can be safe when used properly and with caution. It is important to follow all safety guidelines and wear proper protective gear while using them. Additionally, purchasing a high-quality hoverboard from a reputable brand can also ensure safety.
Most hoverboards are designed to be used on smooth, flat surfaces such as pavement or indoor floors. Some models may also be able to handle slightly uneven surfaces, but it is important to check the specifications of the hoverboard before use.
The battery life of hoverboards can vary depending on the model and usage. On average, most hoverboards can last between 1-2 hours on a single charge. It is important to follow the manufacturer's guidelines for charging and storing the hoverboard to prolong its battery life.
Hoverboards are designed for individuals with good balance and coordination skills. It is recommended that individuals under the age of 13 do not use hoverboards without adult supervision. Additionally, pregnant women, individuals with medical conditions, and those who are not physically able to maintain balance should not use hoverboards.
