How a positive Feedback Amplifier works?
In summary, a positive feedback amplifier operates by feeding the output back into the input, creating a loop. This can lead to an infinite loop, but the loop can be prevented from going on indefinitely by ensuring that the gain around the loop is less than 1. The number of cycles of amplification performed before quitting the loop and producing a final output signal depends on the specific circuit design. Positive feedback amplifiers have various uses, such as increasing gain, producing toggle action, and increasing the Q factor of a resonant circuit. However, they are not ideal for use as signal amplifiers as they can go into saturation levels. Special cases of positive feedback amplifiers include comparators and oscillators. In some cases, a small amount of positive
Frenemy90210
In a positive feedback amplifier, as I understand, output of the amplifier is fed back into the input of amplifier, essentially creating a loop. My question is specifically,
  • how the loop does not go in an infinite cycles ? what prevents it from going into an infinite loop ?
  • How many cycles (of amplification) does it perform before quitting the loop and signals comes out of the final output lead ?
it is a continuous loop
immediately, why would you think that it didnt ?
disconnect the feedback line, where does the signal go ? ____________
reconnect the feedback line, where does the signal go ? ____________
Ohhh, also meant to say
I put your topic tital directly into google and got lots of hits on the use of positive and negative feedback and it's uses
"How many cycles (of amplification) does it perform before quitting the loop and signals comes out of the final output lead ?"
Before I can answer this question I must understand the meaning of "quitting the loop".
Please, can you explain?
Are you certain you mean positive feedback and not negative?
Amplifiers with only positive feedback are never stable. Either the output is going to to sit at the positive or negative supply rail or the amplifier will oscillate (if a capacitor is used for positive feedback). Negative feedback is widely used in amplifiiers to make them more linear. Stability of these can be an issue too. See https://www.allaboutcircuits.com/technical-articles/negative-feedback-part-4-introduction-to-stability/ for example.
Likes NFuller
This probably solves my misunderstanding. I thought -ve feedback amps were used for voltage regulators. The fact that +ve feedback amps go to saturation levels, which means they can not be used as signal amps. They must be negative feedback amplifiers to be used as signal amplifiers.
I don't think it is true that an amplifier with positive feedback is always unstable. It is just that the gain around the loop must be less than 1. There are some properties of positive feedback which are useful, such as increasing the gain of a low gain amplifier, producing toggle action, increasing the Q of a resonant circuit and increasing input impedance.
Likes jim hardy and berkeman
Yes - that`s true.
As another example: Active filters contain (slight) positive feedback effects - otherwise large pole-Q values wouldn`t be achievable.
This is identical with closed-loop poles near the imag. axis. While increasing the pos. feedback factor the poles will move towards the imag. axis - and for infinite Q values (unity loop gain) we habe an oscillator.
Dead right there.
It is sometimes useful to use (a small amount of) positive feedback to make up for losses in a circuit. In the 'old days' of radio reception, many receivers were of the Tuned Radio Frequency (TRF) design. They used a simple resonant filter to select the wanted signal but the bandwidth of such a simple filter was very wide would not reject adjacent frequencies. This is because the poor Q factor of the inductor limits filter bandwidth. A 'sniff' of the output signal from the filter was fed back (positively) to make up for the loss and this produced a much sharper filter. They were not ideal to use as you had to control the amount of feedback with a knob for whichever frequency you were using. If you put in too much feedback you would make the thing oscillate, which sent RF interference out along the aerial wire, annoying all the neighbours.
I believe that the very simple receivers used for radio control (way back) also used TRF circuits.
Likes jim hardy
The 'positive feedback' Sophie mentions was called "regeneration"
https://en.wikipedia.org/wiki/Regenerative_circuit said:
The regenerative receiver was invented in 1912[4] and patented in 1914[5] by American electrical engineer Edwin Armstrong when he was an undergraduate at Columbia University.[6] It was widely used in radio receivers between 1915 and World War II.[3] Advantages of regenerative receivers include increased sensitivity with modest hardware requirements, and increased selectivity because the Q factor of the tuned circuit will be increased when the amplifying vacuum tube or transistor has its feedback loop around the tuned circuit (via a "tickler" winding or a tapping on the coil) because it introduces some negative resistance.
Due partly to its tendency to radiate interference if the regeneration control is set too high,[3][2] by the 1930s the regenerative receiver was largely superseded by other TRF receiver designs (for example "reflex" receivers) and especially by another Armstrong invention - superheterodyne receivers[7] and is largely considered obsolete.[2][8] Regeneration (now called positive feedback) is still widely used in other areas of electronics, such as in oscillators and active filters, and bootstrapped amplifiers.
Being on the verge of oscillation they'd 'whistle' a lot
and that's why 1940's movies so often had a whistle in the soundtrack as an actor tunes in his radio - made it more realistic to audiences of the day..
Same gag as with old ladies' hearing aids. (It was always old ladies in films, for some reason.)
As a user of digital hearing aids (even) I am still guilty of taking people by surprise with a sudden whistle.
There was also the SSB receiver whistle, which would sweep through the whole audio band as they searched for the right BFO frequency.
Related to How a positive Feedback Amplifier works?
1. What is a positive feedback amplifier?
A positive feedback amplifier is an electronic circuit that increases the strength or amplitude of an input signal. It does this by taking a portion of the output signal and feeding it back into the input, resulting in an amplified output.
2. How does a positive feedback amplifier work?
A positive feedback amplifier works by taking a small portion of the output signal and feeding it back into the input, where it is amplified and added to the original input signal. This creates a cycle of increasing amplification, resulting in a larger output signal.
3. What are the components of a positive feedback amplifier?
The main components of a positive feedback amplifier include an amplifier, a feedback loop, and a feedback network. The amplifier is responsible for amplifying the input signal, while the feedback loop and network work together to feed a portion of the output signal back into the input.
4. What are the advantages of using a positive feedback amplifier?
Positive feedback amplifiers offer several advantages, including high gain, low distortion, and increased bandwidth. They are also relatively simple to design and can be used in a variety of applications, such as audio amplifiers, oscillators, and filters.
5. What are the potential drawbacks of using a positive feedback amplifier?
One potential drawback of using a positive feedback amplifier is the risk of instability. If the feedback loop is not carefully designed, it can create an oscillating output signal, which can disrupt the functioning of the circuit. Additionally, positive feedback amplifiers may be more prone to noise and can be more difficult to control compared to negative feedback amplifiers.
