How a spiral torsion spring works
In summary, a spiral torsion spring is a type of spring that stores mechanical energy by twisting or rotating around an axis. It works by applying a torque to the spring, which causes it to twist and store energy. These springs are commonly used in various mechanical systems and are affected by factors such as material, size, and applied torque. Unlike other types of springs, spiral torsion springs work by twisting and have a higher torque capacity, making them suitable for heavier loads.
Bilal01
How spiral torsion spring (used in mechanical watches to store energy) works? physics behind it ? ... I googled it but haven't got a clue. Where should I look for proper and detailed info.
What is so unclueing ?
Can you explain how a diving board works?
Related to How a spiral torsion spring works
1. What is a spiral torsion spring?
A spiral torsion spring is a type of spring that stores mechanical energy by twisting or rotating around an axis. It is typically made from a long, narrow piece of material (such as metal) that is wound into a spiral shape.
2. How does a spiral torsion spring work?
A spiral torsion spring works by applying a torque (twisting force) to the spring, which causes it to twist and store energy. When the torque is released, the spring unwinds and releases the stored energy, which can then be used to power a mechanism or perform a specific function.
3. What are the applications of spiral torsion springs?
Spiral torsion springs are commonly used in a variety of mechanical systems and devices, such as door hinges, clock mechanisms, and electrical switches. They are also used in industrial equipment, automotive parts, and medical devices.
4. What factors affect the performance of a spiral torsion spring?
The performance of a spiral torsion spring can be affected by several factors, including the material used, the size and shape of the spring, and the number of coils. The angle of rotation and the amount of torque applied also play a significant role in the spring's performance.
5. How is a spiral torsion spring different from other types of springs?
Unlike other types of springs, such as compression springs or extension springs, a spiral torsion spring works by twisting instead of compressing or stretching. This allows for a more compact design and greater flexibility in terms of applications. Additionally, spiral torsion springs have a higher torque capacity, making them suitable for heavier loads.
  • Mechanical Engineering
  • Mechanics
