How aircraft reduce fuel splashes inside a wing
In summary, passenger aircraft often have fuel tanks located in their wings. To prevent the damaging effects of sloshing, which can occur when the aircraft tilts, baffles and check valves are installed in the wing tanks. These allow the fuel to flow to the engines while also controlling its movement within the tank. For more information on the design of wing tanks in a business jet, refer to the provided link.
Muti
56
Some passenger aircraft have fuel in their wings. How they manage to reduce fuel splashes inside wing when aircraft tilt left or right for turning. The immediate guess in my mind is multiple baffles to reduce fuel excessive movement. Am I right? Can someone explain or give some link where I can find details of wings containing fuel tank. Also due to aircraft tilt how weight effect from one side of aircraft to other side are countered or are these effects negligible?
The free movement of liquid inside a tank is known as "sloshing", not "splashing". It can cause serious problems if not addressed properly during design. Sloshing is not just a problem for aircraft; any moving vehicle (rocket, airplane, truck, or boat) which carries liquids, either as cargo or fuel, can experience sloshing of the contents of a tank.
Installing baffles inside a tank is one way to limit the destructive effects of sloshing. This method works best for vehicles, like boats or trucks, which travel in a relatively uncomplicated manner. An aircraft or a rocket can move in three dimensions, so reliance on baffles alone may not be sufficient to prevent the damaging effects of sloshing. Another method is to make sure that the dimensions of the tank are proportioned such that anyone dimension (length, width, height) is not excessively long in relation to the other two.
Situations can arise where the vehicle is affected by motions which occur in a period fashion. If the tank's dimensions are not carefully chosen, the sloshing of the contents can develop into a resonant condition, which can lead to large loads imposed on the structure of the tank as the fluid hits it.
Specifically, for aircraft carrying fuel in their wings, the wing tanks are fitted with a system of baffles and check valves which control the motion of fuel inside the tanks while the aircraft is maneuvering, but which are also designed not to restrict the flow of fuel to the engines, which might lead to them shutting down for lack of fuel.
This article discusses the layout of the wing tanks in a business jet:
http://code7700.com/g450_g550_fuel_system.html#wingfueltanks
You can see how the tank and valves are designed to keep fuel flowing to the fuselage of the plane when it is in various attitudes during flight.
Likes Muti
Thank you SteamKing, I will go through the web link.
Related to How aircraft reduce fuel splashes inside a wing
1. How do aircraft reduce fuel splashes inside a wing?
The primary way that aircraft reduce fuel splashes inside a wing is through the use of internal baffles and/or foam liners. These structures are designed to prevent fuel from sloshing around and creating splashes, while still allowing for necessary movement and expansion of the fuel during flight.
2. Why is it important to reduce fuel splashes inside a wing?
Fuel splashes inside a wing can lead to uneven weight distribution, which can affect the stability and maneuverability of the aircraft. Additionally, it can cause fuel loss and potentially create hazards such as fire or explosion.
3. How does the design of the wing impact fuel splashes?
The shape and size of the wing can significantly impact the occurrence of fuel splashes. A smooth and aerodynamic wing design can help reduce turbulence and minimize the risk of splashes. Additionally, the placement of fuel tanks and internal structures can also play a role in reducing splashes.
4. What other factors contribute to fuel splashes inside a wing?
In addition to the design of the wing, external factors such as turbulence, weather conditions, and aircraft speed can also contribute to fuel splashes. Proper maintenance and inspection of the wing and fuel system can also help prevent splashes.
5. Are there any new technologies being developed to further reduce fuel splashes inside a wing?
Yes, there are ongoing research and development efforts to improve fuel splash reduction in aircraft wings. Some potential solutions include using shape memory alloys and smart materials in the design of fuel tanks and baffles, as well as advanced computer simulations and testing methods to optimize wing design for minimal splashes.
  • General Engineering
  • Mechanical Engineering
14K
36K
9K
  • Aerospace Engineering
