How are bubbles removed in a chemical reaction?
In summary, the process of removing bubbles in a chemical reaction is primarily driven by diffusion and surface tension. However, there is no one quantitative equation that can accurately predict this process due to the complexity of factors involved such as adhesion energy, Wan der Waals forces, and viscosity. It is more practical to measure and study the formation and release of bubbles in a reaction rather than trying to model it mathematically. This topic falls under the field of surface and colloid science and there are no simple rules or formulas that can universally apply to all reactions.
Yinxiao Li
46
Hi all,
I am really confused at how bubbles are removed in a chemical reaction. Generally it is removed by diffusion...But is there any quantitative equation for that like adhesion energy...? I want to go in this direction to quantitatively analyse the conditions that bubbles are attached or detached from a reaction surface.
Chemistry news on Phys.org
Sure - bubbles stay at the surface, lifting part of the surface up ... this is held together by the surface tension but the fluid drains off the top until the bubble bursts, releasing the gas.
The alternative is if the tension is high and the gas is lighter than air - then you have to deal with adhesion via Wan der Waals forces and viscocity etc and it gets messy.
It's really the sort of thing you measure, in practice, rather than model mathematically from first principles.
There is a lot of material on how bubbles form, and how they burst, and how they get released from a surface is quite a big study - look up "surface and colloid science". The bottom line is there are no simple rules or formulas that work for just anything.
From a chemical reaction, the surface only delays the release of the gas at the start of the reaction - at some point an equilibrium builds up so the bubble release is at the same rate as the gas is produced.
Likes Yinxiao Li
Related to How are bubbles removed in a chemical reaction?
1. What causes bubbles to form in a chemical reaction?
Bubbles are typically formed in a chemical reaction when a gas is produced as a byproduct. This gas can be released from the reactants or can be generated as a result of the reaction itself.
2. How do bubbles affect the outcome of a chemical reaction?
Bubbles can affect the outcome of a chemical reaction by changing the rate of the reaction or altering the reaction conditions. For example, if a gas is produced and trapped in the reaction mixture, it can create pressure and inhibit the reaction from proceeding.
3. What methods are used to remove bubbles in a chemical reaction?
There are several methods that can be used to remove bubbles in a chemical reaction. These include using a vacuum pump, stirring the reaction mixture, or adding an anti-foaming agent to break up the bubbles.
4. Why is it important to remove bubbles in a chemical reaction?
It is important to remove bubbles in a chemical reaction in order to get accurate and consistent results. Bubbles can interfere with the reaction and affect the amount of product produced, making it difficult to accurately measure the reaction's yield.
5. Can bubbles be completely eliminated in a chemical reaction?
While it is difficult to completely eliminate bubbles in a chemical reaction, steps can be taken to minimize their presence. This includes proper mixing and using techniques to remove or prevent the formation of bubbles. However, in some reactions, bubbles may still be present to some degree.
