How are dark energy and matter quantified?
In summary: I'd still like a quotable authority that I can reference when writing something relevant.In summary, about 68% of the Universe is dark energy, 27% is dark matter, and less than 5% is ordinary matter. These estimates are based on data from the PLANCK mission, which has measured the density parameters Ω_b, Ω_c, and Ω_Λ, representing baryonic matter, dark matter, and dark energy respectively. These values are often given in the form of Ω_{whatever}h^2, where h is the Hubble constant divided by 100. The densities are typically listed as fractions of unity and can be calculated using various methods, such as observing anisotrop
gnnmartin
83
To quote http://science.nasa.gov/astrophysics/focus-areas/what-is-dark-energy/, "It turns out that roughly 68% of the Universe is dark energy. Dark matter makes up about 27%. The rest - everything on Earth, everything ever observed with all of our instruments, all normal matter - adds up to less than 5% of the Universe. "
I know (roughly) where these estimates come from, but I don't see how we quantify them. My best guess is that viewing the universe as a spatial 3 sphere (ie everywhere similar) with time running at the same rate everywhere, we can estimate the amount of 'ordinary' matter per unit volume, assuming pressure is a negligible, and we can estimate the 'mass equivalence' of any dark matter (ie the extra mass suggested by the speed of rotation of galaxies), and then the 'negative mass equivalence' suggested by the rate of acceleration of expansion of the universe.
Is that roughly how the percentages are calculated? Is there an authoritative source to quote?
Space news on Phys.org
Roughly, yes.
Thanks. I'd still like a quotable authority that I can reference when writing something relevant.
You can use PLANCK mission's data release papers. Such as these latest ones: http://www.cosmos.esa.int/web/planck/publications
You'll most easily find results for baryonic matter/dark matter/dark energy densities in the overview (first) paper. There are also various methods used listed there (baryon acoustic oscillations power spectrum, gravitational lensing, etc.).
If nothing in those papers rings any bells (they are highly technical), you want to look for ##Ω_b## for baryonic matter density, ##Ω_c## for dark matter, and ##Ω_Λ## for dark energy. There's usually a table or two in there. For various reasons, those values are often given in the form of ##Ω_{whatever}h^2##, where ##h## is the Hubble constant (##H_0## always also given) divided by 100.
The densities Ω are given as fractions of unity (i.e. 10% is 0.1 and so on).
As an example of a method of getting those values, lots of information can be gleaned by observing the anisotropies in CMBR (the clumpiness of deviations from homogeneity). The page listed below has some nice animations showing how changing the parameters of the model (densities of various components) changes the expected power spectrum. It can then be compared with observations of CMBR to see which set of parameters fits best to what is seen.
http://background.uchicago.edu/~whu/metaanim.html (switch between the tabs on the left)
The tutorial section will walk you through the reasoning behind those measurements, and why they are a proxy for those densities.
Many thanks, very useful. I'll study that.
I was aware of the pivotal role of Ω, but it is hard to look for that, even in the index of a textbook. Does this value have a name other than omega that one can expect to find in an index?
It's called density parameter(s). The problem with looking for it in an index as a phrase is that many papers don't even bother writing it in any other form than Ω, because it was defined some place earlier or is obvious from the context (obvious to those at whom the paper is aimed, that is). Quick skimming of the 2015 PLANCK overview paper seems to indicate that they didn't bother with naming the terms they list in tables (they did in earlier releases - e.g. the 2013 one)
Note: I made a mistake above (now edited out) - I listed ##Ω_m## for dark energy, whereas that's the total matter content (baryonic+dark). Dark energy will be listed either as ##Ω_Λ##, ##1-Ω_m## or left out completely since for present values and a critical density universe it's whatever is left after deducting matter density and the now-negligible radiation density from unity (so it's obvious; e.g. 30% matter density implies 70% DE density).
Thanks.
FAQ: How are dark energy and matter quantified?
What is dark energy and how is it quantified?
Dark energy is a hypothetical form of energy that is thought to make up approximately 70% of the universe. It is believed to be responsible for the accelerated expansion of the universe. Dark energy is quantified through observations of the expansion rate of the universe and the distribution of matter within it.
How is dark matter quantified?
Dark matter is a form of matter that does not emit, absorb, or reflect light, making it invisible to traditional detection methods. It is quantified through its gravitational effects on visible matter and the cosmic microwave background radiation.
What methods are used to study dark energy and matter?
Scientists use various methods to study dark energy and matter, including observations of the cosmic microwave background radiation, gravitational lensing, and large-scale structure surveys. They also use computer simulations and mathematical models to better understand the behavior of these elusive substances.
How do scientists measure the amount of dark energy and matter in the universe?
The amount of dark energy and matter in the universe is estimated through various techniques, such as measuring the gravitational lensing effects on distant galaxies, mapping the distribution of matter in the universe, and analyzing the fluctuations in the cosmic microwave background radiation.
Can dark energy and matter be directly observed or measured in a laboratory?
No, dark energy and matter cannot be directly observed or measured in a laboratory because they do not interact with light or other forms of electromagnetic radiation. They can only be studied through their effects on visible matter and their influence on the structure and expansion of the universe.
