How are degrees of freedom understood in QM?
In summary, degrees of freedom refer to the number of independent variables needed to describe the state of a physical system. In the context of Quantum Mechanics, the number of degrees of freedom for a system of N particles is 3N, but for a quantum field it is infinite. The observer is assumed to be outside the system and not represented in its state space. Observation does not change the degrees of freedom, but only the specific state in the system's state space.
Posy McPostface
I'm having a hard time understanding 'degrees of freedom'. Could someone please provide an example in terms of Quantum Mechanics about what a 'degree of freedom' could be represented as? Is it simply a number of observations of a physical system to determine the arrangement of particles within that system? Does the accuracy increase with a number of observations made or is one observation enough?
On a deeper level, is there a demarcation that can be said about the observer and the state space of a system or does that line blur away once an observation is made?
For a system of N particles, the number of degrees of freedom is 3N, one for each position coordinate of each particle. On the other hand, a quantum field has an infinite number of degreeess of freedom.
This is the most typical usage. In a generalized sense, one may consider other (e.g., spin) coordinates as degrees of freedom but this is far less common (and must be inferred from the context).
In any case, this has nothing to do with observation.
The observer is conventionally always assumed to be completely outside the observed system, and hence not represented in the latter's state space.
Likes bhobba
Thank you for the explanation. I understand now.
Doesn't the observer interact with the system by observing it and thus affecting the degrees of freedom in the new observer-state space?
Observation doesn't change the degrees of freedom but only the particular state in the state space of the system.
Related to How are degrees of freedom understood in QM?
1. What are degrees of freedom in quantum mechanics?
Degrees of freedom in quantum mechanics refer to the number of independent variables that are required to completely describe the state of a quantum system. In other words, it is the number of ways that a system can move or change without violating any constraints or laws.
2. How are degrees of freedom determined in quantum mechanics?
In quantum mechanics, degrees of freedom are determined by the number of quantum states that a system can occupy. This is often represented by the number of energy levels that a system can have, or the number of possible positions and momenta that a particle can have.
3. Why are degrees of freedom important in quantum mechanics?
Degrees of freedom are important in quantum mechanics because they allow us to understand and predict the behavior of quantum systems. By knowing the number of degrees of freedom, we can calculate the number of possible states that a system can occupy, and make predictions about its behavior under different conditions.
4. How do degrees of freedom differ from classical mechanics to quantum mechanics?
In classical mechanics, degrees of freedom refer to the number of independent coordinates required to specify the state of a system. In quantum mechanics, degrees of freedom refer to the number of quantum states that a system can occupy. This is due to the probabilistic nature of quantum mechanics, where a system can exist in multiple states simultaneously.
5. Can the number of degrees of freedom change in a quantum system?
Yes, the number of degrees of freedom in a quantum system can change. This can happen when the system interacts with other quantum systems or when energy is added or removed from the system. In some cases, the number of degrees of freedom may also change due to the effects of quantum entanglement.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Interpretations and Foundations
  • Quantum Physics
  • Quantum Physics
